Old 03-29-2017, 09:07 PM
Northern Farmer's Avatar
Lightbulb Volvo CX400 RC excavator
Never seen this RC excavator before looks like it would be a lot of fun to operate.
http://www.csmi.com.au/index.php?rou...product_id=529
Bases on a OEM model
Machine is full RTR ( Ready to Run ) .
Complete crated with wooden box.
This new generation excavator is a full hydraulic remote controlled scale down version for the real equipment. This RC excavator can be used in the dangerous environments and is safer than the tranditional excavator. It can reduce the risk of suffering injury when user needs to work in high risk areas or handing dangerous materials . The operator may install a camera on CX400 for remote operation . In other words, this excavator can work even if the operator is not in the work area. WithCX400 is also a good helper to plant trees and prepare the soil. It can not only reduce manpower but also increase work efficiency. Makes gardening easier and more fun!
Features:
● With its small size design it can be used in narrow and dangerous areas,and reduce the risk of concern.
The Excavator is fuelled by gasoline.
● The Excavator can rotate 360 degrees easily without interference of power cord.
CX400 Details :
Weight: 700 kg
Width with track: 143 cm
Height : 155 cm
Engine output : 9 kW
Max. Travel speed : 3 km/h
System pressure : 100 kg/cm2
Max. Pump flow : 36 L/min
Attachments including: Buckets and Concrete Crushers. The concrete crusher can crush concretes, cut reinforced bars and grip explosives.
