Old 07-15-2017, 11:43 AM
Yard Toad Yard Toad is offline
Yard Toad is on a distinguished road
Default Re: eagle mach dozer first time run help
Congratulations on your new dozer!!! glad to here you got the hydraulics working as they should.
If I can, I would like to suggest a few things that i have found to be helpful with my dozer. Be sure you inspect for loose 2mm screws, loctite your track pins as they want to work their way loose and drag on the bottom roller guides, check and set your end points (pump speed) mine came set too high!!! 100%. Also make sure you are only powering your receiver with one power source. Mine had multiple power sources feeding it. You will have to remove some red BEC wires to do this. Hope this helps, and keeps your machine running strong!!! Really have enjoyed mine!!
