Thread: radio input
Old 01-09-2011, 08:47 PM
Default Re: radio input
Originally Posted by egronvold View Post
- Switch between at least 10 models without turning them off
Hold on a second here. Yes, you can select a different model on the fly, from the radio's memory, but any receiver, in a model, left 'on', would still be receiving a signal. In effect, you'd be controlling more then one model at a time, but the programming of each model would have them all doing something different then expected (except for the one that is currently pulled up on the radio). I.E. servos may be reversed, on certain channels, end point adjustments would be off, ect. Just because you switch the current model, in the model memory, does not mean the other models will go into stand-by mode. If any receiver is bound to the tramsmitter, it will continue to do whatever the radio signal says it should.
