Thread
Dozer conntrol question
10-22-2017, 11:52 PM
TheBennyB
Re: Dozer conntrol question
Using the stock TX here are some screen shots of the mixing I was given from a fellow in AUS. I still had to switch the motor esc's in the RX to work correctly and reverse a channel or 2. You may not. Sorry for the fuzzy stills. Main thing to check are that the Mix 1 and 2 are "on" in the upper right of the screen. I reassigned the ripper to toggle buttons "E" and "G" on the TX. Also if you go this route your TX will now have a blinking red light next to the solid green light of TX power. No worries, this is just an indication that a channel mix is active.
12:18 AM
TheBennyB
View Public Profile
Find all posts by TheBennyB
