Old 02-15-2018, 07:31 AM
Default Re: Joskin KTP27/65 Tridem
Return side? Yes, you will max pressure when cyl deadheads for a second or two... might get away with it for 20 - 50 lifts, but that hyd line is always ever so little ballooning with pressure... better safe than oil spraying everywhere, no fun to clean up.
When you disassemble for paint, do you cut the hose off the barb or force-ably pull it off? ...I always split the hose with a #11 knife off the barb.
What's the loading height of your box from the ground?
