Old 04-28-2019, 04:39 PM
Default most realistic radio operation for semi?
question... is it possible to use the full travel of the throttle, but then flip a switch and the throttle becomes full travel brake/ reverse/
here's the scenario:
i'm using a frsky qx7 with beier esc/ sound module, on tamiya semi. i can set it up so that it has gear changes. so to start: trans in 1st, throttle 0.. run throttle to 100% and have simulated 3 gear changes, flip the transmission to 2nd gear, throttle back to 0, and repeat... same with 3rd transmission gear.
for braking, i'd like to flip a switch, so that i can use the full throttle throw to slow down, and ideally have jake brake sounds
this may be just too complicated..
