Old 08-20-2010, 02:49 AM
SonoranWraith's Avatar
It's a dry 115 degrees.
Default Re: Silverado Dually in 1/14
trucker n post whoring all over the board.
I took a size comparison shot of the semi vs 60d tires unmounted:
And here is a comparison of the width after narrowing the 60d's to the semi tire:
Narrowed vs un-narrowed 60d's mounted:
Front clip from 18r seems to be a good width (shown with 18r wheel/tire):
I do have an issue with the stub axles though. Stock 18r's are to short so I had to order the 18t's (left)
Latest issue is that the stub axle is 4mm at the pin location and 3mm for the rest. I am not planning 4x4 yet but could add later. To mount up the stock semi rims I need two 3x11 bearings. McMaster only has 3x10. I found them at boca but they are 20 bucks a pop! Anyone know where I could get some cheaper?
