Old 12-09-2011, 07:04 PM
JensR JensR is offline
Default Re: 12 channel radio and high torque motor question
If you are not using all channels at the same time, you can just switch a bank of servos off and another one on. Problem is that your trim and endpoint adjustment will be shared between both banks.
If the functions are only on/off (outriggers in or out, axle up or down), you might get away with even simpler stuff.
