Old 09-04-2010, 02:44 AM
Default Re: *gear reduction unit
Originally Posted by CustomRCmodels View Post
Joe ,
Don’t you use the 3:1 version of the Wedico double-motor coupler type I made up for Ric ?
I don’t remember if I had send you the gear to do that yourself , or if you did get it from Ric ?
Yeah, that's part of the 6.2 additional reduction. 3:1 in the twin motor coupler and 2.1 in the t-case.
Nathan, with the 55 turn motor and 3:1 axles, I'd think you'd want 25 or 30:1 planetary box. Your wdc tires will be about 15mm smaller diameter.
