Old 09-05-2010, 10:01 PM
Default Re: Perry's Leimbach Build
You wrap the wires thru the ferrite rings at least three times, helps to cancel out the interference. Do the pump, each track motor and with the micro servos, just twist all three leads together. I have virtually no interfence with my Stahl excav.
Leimbach's esc, pic 27 in the manual (from left to right) plug for BEC, +/- main switch, +/- swing motor, track motor. It clearly depicts in the photo which terminal is positive & which is negative --> don't mix them up! The red wire with a black stripe is NEGATIVE ground.
