Thread: Transmissions
Old 02-21-2012, 04:34 PM
Aero 9000's Avatar
Aero 9000 Aero 9000 is offline
Aero 9000 is on a distinguished road
Default Re: Transmissions
Originally Posted by sparkycuda View Post
One difference between 1:1 and our equipment is the prime mover RPM. Diesel engines have a very narrow power band and low max RPM, requiring multi-gears to match available power/torque and road speed. Our electric motors have a considerably wider RPM range, depending on turns, etc. I chose a low RPM 85t motor for my Payhauler. It turns 5200 RPM at 7.4V, so is about double the diesel engine RPM in the real truck. By using a 3-spd trans, I just about replicate prototypical road speed, since the 1:1 had a 6-spd trans. Lower turn motors spin a lot more RPM, reducing the actual need for a many-gear trans - use of one speed or a 2-spd trans works just fine since we seldom see anything like scale speed (70 MPH) with our trucks.
But then, nothing beats shiftin' those cogs 9 times going across the room! To each his own - just have fun doin' it.
Yes Ken.....you got it...... to each his own...!!
I've been experimenting with 12volt RS555 motors running on 7.2 volts.
In that configuration they act more like the diesel, it's more of a challenge to drive, and more realistic, they drive like a truck instead of a sports car.....the spin off is the batteries last for ages...
