Thread: RCLogger
Old 04-13-2012, 11:34 AM
RCLogger's Avatar
RCLogger RCLogger is offline
Default Re: RCLogger
Originally Posted by crusher View Post
Greg I read in your post that you use teflon for the track chain to slide on. Could you elaborate a bit. Are the rollers that show just the outside profile of a roller with the teflon mounted to the track frame?
Thanks
Terry
That is correct Terry, on the D8 those are just made to look like there are rollers, but it has teflon strips so that it keeps the track running smooth no clogging and aligned. The excavator has teflon as well, milled out for the chain width so that the chain runs inside, can't jump out of slot, no binding..
greg
