Old 09-25-2012, 03:45 AM
motocrawler motocrawler is offline
motocrawler is on a distinguished road
Default Re: Bruder Liebherr 574 Conversion
The next step in the process was figuring out how to make the articulated portion of the loader work. As easy as the photos make it seem I actually spent a lot of time trying to figure out what would give me full travel and yet be out of the way and not require to much hacking of the body/chassis.
Now came the tricky part, how to get power to the wheels. I am using Tamiya semi axles as they are a exact match width wise as the original axles. This was a serious multi step process with a lot of swearing and head scratching.
Step 1: Mask and cut clearances for axle, the point of no return!
Before
After
Step 2: Make brackets to hold the axles to the chassis
Step 3: Lock the diffs-a nifty little trick-insert a 4th bevel gear and viola she is locked
Step 4: Paint axles and brackets and assemble
Step 5: Mount axle to chassis
