Thread: Riding High
Old 09-26-2010, 09:09 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Default Re: Riding High
You can change the ride hieght by adding shims between the springs and axles but your ground clearance will not change unless you put bigger tires on. The ground clearance under the axles will remain the same until you do this.
