Old 01-01-2013, 04:44 PM
Default Re: How to make hydraulic valve?
Originally Posted by ihbuilder View Post
JW : steel or iron next to brass would be the best choice for your manifold . Aluminum does not wear well .
Madda : O-rings work well for the seals as you should only have to seal the shaft of the rotor and the rotor cap . between the rotor and the valve block , you should have a lapped fit .
I agree with Steve 100%. The valve that I made for my skidder is all aluminum with brass rotors but it may not last long. The valve block that my father in-law made for my EC300DL has a steel manifold and should last much longer. The shafts are sealed with common O rings on both. The EC300 runs at 30-35 bar with no leaks on the valve shafts.
