Thread: Paint Removal
Old 07-21-2013, 03:59 AM
Bigrigger's Avatar
Default Re: Paint Removal
This was mentioned by Stuart in my Volvo Flatbed thread, but I thought I should repeat it here.
He uses an improvement on the FGD method, adding 50% acetone (or I used lacquer paint thinner) to the mix. This method is more effective, and works well on older paint, which is harder to remove.
I used the 50% rubbing alcohol and 50% lacquer thinner mix to easily remove paint from my cab. Although, I'm not sure if soaking it is the best idea, as the thinner was still very aggressive.
All credit goes to Stuart for his 50/50 acetone mix. Thanks buddy!
-Chris
