#141
Have you talked to a tire store, about urethane fill for your truck tires?
Cheers, Neil. |
#142
I think he should put the tubes back in and run nitrogen... Don't want that tire pressure to change with all that heat build up while hauling!
#143
Yeah you wouldn't want it to burn up like that haul truck at the Meadowbank gold mine!
#146
Nope....truck/tire fires are no fun....they burn for days....
#147
http://blog.otrwheel.com/what-is-pol...-does-it-work/ Go talk to a tire dealer that handles forklift and industrial/construction tire's, and they can give you more detail's, I don't think you need more than an "8" on the durometer scale, but inflate your tire's to the desired pressure, and tell the dealer to match it with the fill. Spray foam at home depot is NOT the same stuff. Hope this help's ![]() ![]() ![]() cheer's, Neil. |
#148
We have an old lawn mower that we use for towing trailers around the property. We had a tire shop fill the tires with foam. We still haven't had any problems with the tires even with the chains and a load on. So i'm sure whatever they used will work for you!
Jarrett |
#149
Thanks guys for the tire fill info......that would be a good solution......the only draw back might be the added weight,not like this thing is a feather weight now...lol....
#150
Didn't get much done in the last few days other than work on the fuel tanks....sorry no pics yet...oops...
So here is a recap of the truck and a list of suppliers Truck size... Length- 32" Height - 16" Box width - 17.5" Weight- Hard on the back....lol Steering servo (3.5 turn winch servo) http://hitecrcd.com/products/servos/...-servo/product Servo gear (12T -32P) http://www.servocity.com/html/32p_hitec_metal_gear.html Box hoist (9" - 35lbs linear actuator) http://firgelliauto.com/product_info...products_id=13 Two speed controllers (one for drive,one for hoist) http://www.robotmarketplace.com/products/0-SYREN25.html #25 chain and sprockets http://www.robotmarketplace.com/prod...s_main_25.html Geared motor http://www.robotshop.com/ca/en/baneb...motor-kit.html http://www.robotmarketplace.com/products/0-PDX256.html Tires and rims http://www.princessauto.com/pal/en/S...mbly/8442410.p |
#151
At least you might be the first to say even the weight was accurately scaled down!
Nathan |
#152
This truck is turning out to be much heavier than I thought....yikes...cutting it from solid material is a big reason for the added weight, at least something might be close to scale.....lol
#153
From my experience with racing go karts where the tires have to reach an optimum operating tempature of 165* F, when I ran tires with air or nitrogen they both reacted the same as far as how much air pressure was increased and it also took the same amount of laps to build the same heat and air pressure!!! With all that being said, I would look into foam filling the tires to achieve what you want!!! Also my wife's new nissan cube dropped air pressure from the recommended pressure of 44 psi to an average of 20 psi when the cold weather set in, and they are nitrogen filled also!!! Hope this helps!!!
#154
Made a new cab today (cut from 14ga)....needed to make some changes...so I added holes to attach the windows and the grab bar at the same time. Decided to use fasteners to attach the windows....the upper portion of the cab will be painted black so the fasteners shouldn't stick out to bad....
![]() [IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG]
#155
Nice! So jealous!
Maybe you should get some button head screws???? Not picking, just a suggestion. |
#156
Thanks.....button heads would most likely look better....don't have any that small...yet...lol
#157
Metal origami, That's a neat way to build!
Cheer's, Neil. |
#158
! Very nice model you are making, interesting way of solving the ribs on body! A tripple 7 have always been a favorite for future modeling project, did find a 2nd hand model in 1/87 from CCM yesterday, can be useful for reference. ![]() ![]() /Dan |
#159
Metal origami...lol...never thought of it like that before...but your right, thats kinda what it is
#160
| Currently Active Users Viewing This Thread: 27 (0 members and 27 guests) | |
| Thread Tools | |
| Display Modes | |
