Old 12-14-2010, 07:18 PM
ihbuilder's Avatar
Default Re: Manufacture Hydraulic Pump?
OK , now I know the slang for it , sickle gear is nothing more then a vain . most furnace pumps are vain pumps as far as I know . I got my seal for mine ,just did not get it installed yet . I've been busy with wheel orders and a job that finally came up . I have no doubt about flow rate , just skeptical on pressure . My dad has suggested a furnace pump also ,I just did not get there yet . I have a couple
IHSteve
Old 12-15-2010, 07:17 PM
ihbuilder's Avatar
IHSteve
I stand corrected , a sickle gear set is just what the jung pump has . I finally got to take a furnace pump apart and ohlala just what I've been looking for and the right size to . now to make the right size housing for it ,HMMMMMM come to think of it , I think the newer furnace pumps are about the right size . oh more research
Originally Posted by Bellien View Post
If you are still considering building a pump, have you considered using the sickle gear set out of a furnace oil pump?
thank you so much for bringing this up made me check it out sooner then later
IHSteve
Old 12-15-2010, 08:59 PM
trucker n's Avatar
what is a furnace pump
Old 12-15-2010, 09:05 PM
ihbuilder's Avatar
oil furnace to heat your house , unless you live where it's a constant 90 deg all year round .
Old 12-15-2010, 10:19 PM
trucker n's Avatar
i have heat but dont use it much and it is gas so no pump where can i get one
Old 12-15-2010, 10:29 PM
ihbuilder's Avatar
Neil , the pump as it comes is to bulky to fit in a model . the way I figure , all that is worth out of the pump is the gear assembly . I'll be making a new housing to be able to fit in a construction model . I should be able to get it close to the jung pump size . but if you want ( beckett )
IHSteve
Old 12-19-2010, 03:15 PM
Bellien Bellien is offline
Bellien is on a distinguished road
Let me know how it goes, it would certainly be a cost saver if it was reasonable to re-build them..
Old 12-31-2013, 09:27 PM
Stepside's Avatar
Stepside Stepside is offline
Super Moderator
Stepside will become famous soon enough
Originally Posted by Vanisle View Post
UMs also sells pumps:
http://www.umstech.in/searchproduct....d_201010218555
Doesn't FGD have some in his projects?
Anyone know where to get these pumps???
"If you build it, they will come"
East Coast Mini Truckers
Old 01-01-2014, 11:08 AM
ihbuilder's Avatar
working on it
not sure on buying looks like UMS went into the commercial arena .
I should be able to stay close to their price range , NO LESS , depending on a good shaft seal price .
Old 01-01-2014, 01:20 PM
22fatcat's Avatar
22fatcat 22fatcat is offline
22fatcat is on a distinguished road
Hi, I have built two pumps, the first one was very loud and it moved to much oil not very efficient. the second one i used a much smaller gear and it seems to work pretty good but it has not been used on my excavator yet I just recently bought the spool valve from Rc4wd and need to finish the connections and make an overflow tank. Hopefully this one will work well.
Old 01-03-2014, 08:28 PM
Stepside's Avatar
Super Moderator
I emailed UMS, but doubt I'll hear anything back.
Any idea on when you could get a prototype built? There's a demand here and you're the guy to fill it!!!
I would rather my money stay in the US and what better than to support one of our own. Go get 'em Stevie!
Old 01-04-2014, 10:23 PM
ihbuilder's Avatar
as soon as motors and gear stock come in and someone has me tied up for this month
i'd say a month or 2 also you know what else is coming
Old 01-04-2014, 10:36 PM
I'm out of the loop! What else is coming?
Old 01-05-2014, 09:40 PM
ihbuilder's Avatar
well it comes after a valve and does some work
I'm waiting on mtrl quote so I can order mtrl . dang holiday's and weather messin things up hopefully better this week
Old 01-07-2014, 12:15 AM
petermoblin petermoblin is offline
petermoblin is on a distinguished road
This wouldn't be a multi-stage cylinder would it Steve
Look'n neat with no air in the seat
Old 01-08-2014, 07:59 PM
ihbuilder's Avatar
Copyright ©2000 - 2026, Jelsoft Enterprises Ltd.
