#181
You be funny guys....
![]() (Thanks Reg...see what you started with the blue balls!!!?? ![]() stop spending so much time in the shop......![]() ![]() )
#182
Haha! I've been told that I am a bad influence before....
#183
I can't stop laughing at the comments you knuckle heads come up with
![]() (guess the color blue shows how dedicated we can get to this hobby.... )
#184
Guilty as charged
![]() ![]() ![]() Cheer's, Neil. |
#185
![]() ![]() The spacers I cut from plastic are not a true beadlock......just a way of keeping the tire in contact with the rim...originally I had hoped the tires alone would be enough to carry the load without the air filled tubes but the side walls are too thin....so being that I will only have tubes on the inside tires on the rear duals I needed to make the outside tires look the same somehow (the air filled tires are taller)....and the racquetballs seem to be a way to solve the problem....hope this makes sense...... [IMG] [/IMG]
#186
That is a very nice idea. You can't just leave the air pressure low in both tires it would seem they would squat with a load in them if the pressure was low in both tires. Just an idea. You are doing a great job on the build and it will be heavy. Ed
#187
Thanks Jammer.....using air filled tubes on all six tires would be good, the problem is in hiding the valve stem on the rear outside tire....rather not see a valve stem on the outside....the rims are two pcs and must be mounted before adding air, and there is no room to get at the valve stem between the duals if I put the valve stem toward the inside between the duals....hopefully the "racquetballs" will work instead of a tubes on the outside duals, time will tell......
#188
#189
You might try Canadian Tire and get a valve stem extender. Then you can drill another hole in the inside rim to bring it through the back. They make them a million different ways for every need.
Cheers Rob https://www.google.ca/?gws_rd=cr&ei=...stem+extenders |
#190
You can also try a RV dealer they will have a assortment of valve steam extension also..
Wayne |
#191
Looks good-what is the purpose of the gear next to the sprocket on the drive motor? I saw this on the pictures of the sprocket when you were making them and didn't understand but thought it would make sense later, but I still don't get it.
#192
[IMG] [/IMG][IMG] [/IMG]
#193
Does anyone have any experience with this smoke generator???
#194
OOPS!!.....try again...
http://www.harbormodels.com/site08/m...ges/smoker.htm Thinking of adding it to the truck later on..... (Wish it was black smoke....white smoke from a diesel is usually a bad sign... .....)
#195
#196
How are you doing? Once again a very nice job. It won't belong now will it before you are going to be carry a load? Like they say all good things take time. Ed
#197
Thanks again....all the small little things that need to be done all take time, longer than a person thinks..lol..but for the most part I think all the little stuff is done at this point, so I hope to get started at all the welding etc in the next few days....
#198
#199
#200
Coming right along! Must be almost ready for paint
| Currently Active Users Viewing This Thread: 16 (0 members and 16 guests) | |
| Thread Tools | |
| Display Modes | |
