Old 02-07-2014, 03:26 AM
Default Re: 777 HAUL TRUCK (1/12 size)
Well almost done, eh? Weld up the box, give it a coat of paint & you're off to the races!
Originally Posted by DADSGARAGE View Post
An "OMAX" 55100 waterjet table retails for about 200K US$
Lucky you! my combine costs nearly triple that, but I don't get to use it for my hobby too.
Old 02-07-2014, 06:52 PM
dirtpusher9's Avatar
Moderator
Well that should carry a LOAD. Great work.
Old 02-07-2014, 08:39 PM
pigeonfarmboy's Avatar
This thing is so awesome! Love how slow the steering operates! The bucket needs bump stops it's so fast haha.
Old 02-08-2014, 02:38 AM
DADSGARAGE's Avatar
Thanks for the comments guys.....it's always fun to actually see a project come to life for the first time while doing some testing, a person finally gets to see if all the time and effort was worth it, even if somethings may not go/work as planned...so far the truck seems to be working fairly well, but I have already found a few small things that will need to be changed.....
I welded the panels in the box today, still need to grind/sand all the plug welds off and finish a bit more welding but for now it's good enough for some testing....really want to see how this thing will carry a load...
Here is the LOAD TEST VIDEO
http://www.youtube.com/watch?v=F4nfF...re=c4-overview
Steering still seems alright (look for the front tire marks on the floor) but the actuator is really working hard to lift the "110lbs load" of sand....but it did manage to lift it
Old 02-08-2014, 05:16 AM
Hofabooz's Avatar
Hofabooz Hofabooz is offline
Hi
Looking great and what a great load capacity.
What would it's load capability be if scaled up to life size, just curious ?
great work cannot wait to see it in paint finished and then used in anger.
Thanks for posting.
Regards
Mark
Old 02-08-2014, 06:29 AM
titandigs's Avatar
Aussie Fabricator
Hey Kordell,
Great to see it running, you must be very happy.
What size is the Honda? in the back ground?
Old 02-08-2014, 09:45 AM
crawler07 crawler07 is offline
crawler07 is on a distinguished road
I was so worried you would run into your atv and damage something (on the atv) LOL
Amazing work! What was the weight on your first load their?
Old 02-08-2014, 12:36 PM
That truck would fit right with our RC strip mining operations. Too bad you live so far away.
Old 02-08-2014, 02:16 PM
DADSGARAGE's Avatar
Originally Posted by Hofabooz View Post
Hi
Thanks for posting.
Regards
Mark
Thanks.....a 777 truck is rated for 100 tons, so if I did the math right the scale load would be around 127 lbs.....(220,000lbs / 12 /12 /12 = 127.3lbs)
Originally Posted by titandigs View Post
Hey Kordell,
Yes very happy to see it working even if it isn't finished
It is a Honda ES350
LOL....I though I was going to hit it too...LOL...glad I didn't hit it or the garage door....would have wiped out the side deck and railing...might have ripped a tire off the ATV
The load on the truck was about 110 lbs.....
Old 02-08-2014, 09:18 PM
Fired up Fired up is offline
wow looks and works great
Old 02-10-2014, 03:50 PM
FlyingBeagle's Avatar
FlyingBeagle FlyingBeagle is offline
FlyingBeagle is on a distinguished road
Wow, Just awesome. That truck truly is a beast.
How did the suspension handle the load. Was it bottomed out, or is there still some travel remaining. What about the drive motor, Do you think it will be able to handle much of a grade. I am sure Joe would love to know if it could make it up his basement ramps to the window outside.
Old 02-10-2014, 04:58 PM
Markus K. Markus K. is offline
Markus K. is on a distinguished road
That's an awesome and really beautyful work! Thumbs up!
Markus
Old 02-11-2014, 08:34 PM
Wow! The Cat 777 is looking better than ever! I can't believe how nice all of the seams look, after you've welded them up. Must have taken a lot of time to get the seams so smooth and perfect. Lots of sanding by hand?
Old 02-17-2014, 11:58 PM
DADSGARAGE's Avatar
Thanks!!!
Thanks.....surprisingly there was still some more suspension travel but not much...about 1/4" in front and about 3/8" in the rear...I would say that a load of 110 lbs would be the max for the suspension....can the motor pull that much load up an incline??? Not sure...sounds like a reason to make another video and see what it can do or find out what it can't do!!
I think Joe's ramps are a bit too narrow for this truck...and he would need a bigger "window" to drive out...LOL
Markus
Thnaks glad you like it....keep up the great work on your build!!!
Thanks...it is looking more like the real deal all the time...welding all the seams without warping everything takes some time but sanding all the welds takes even more time, used "Walter" spin on sanding discs to blend all the joints and a table top belt sander from Canadian Tire to help get it all straight.....no hand sanding yet...that will be after using body filler...fun fun...not!!
http://www.walter.com/Walter/en-ca/a...o-flex-spin-on
Old 02-18-2014, 07:14 PM
RCKiwi RCKiwi is offline
RCKiwi is on a distinguished road
Everything about this dumper is the business! Way tough enough with bags of detail to boot! I've enjoyed watching this beasty evolve.
Congrat's!
Glenn
Old 02-21-2014, 09:06 PM
od jhon deer od jhon deer is offline
od jhon deer is on a distinguished road
u said u was having trouble with tires holding up the weight if they r air filled put more air in them if u thank the tubes wont hole and start leaking braze the middle of the 2 rim halfs together r u can try that spray foam in a can u get at hardware stores for sealing cracks in the house spray it in let it set up trim off excess put rims back together that stuff sets up pretty hard at least ways that is just a suggestion if u don't want to use air but those tires with air should hold just fine with more in them I have some like them and I have a 3 hundred lb toll chest on there no problem just a thought
Old 02-23-2014, 05:16 PM
DADSGARAGE's Avatar
Made a short video...
LOADED INCLINE TEST VIDEO (6 degree incline)
http://www.youtube.com/watch?v=dXzfv...cnElm7fYjN3bEA
Old 02-23-2014, 08:18 PM
So have you got a protractor handy? Would it be 5°?
Doesn't seem to struggle at all, eh?
Old 02-23-2014, 09:24 PM
Trucker_Jo's Avatar
Looks like that has plenty of power for those open pit mines your going to be digging once you get that shovel built I'm suprised that those boards didn't break under the weight of that machine
Jarrett
Old 02-23-2014, 10:20 PM
DADSGARAGE's Avatar
I placed a "magnetic angle finder" on one of the 2x4 and read about 6°, that little motor gear box puts out a huge amount of power....and it will hold the truck from moving on the incline....time will tell how long it will last before it tears itself apart???
It does have plenty of power considering how small the "Banebots" motor/gear box is....but again time will tell how long it will stay together, I could see the last set of planetary gears getting damaged using it to this extreme....surprisingly the 2x4 boards actually didn't even bend much with that much weight on them, I put my weight on them first just to be sure they would be OK...I was hopeing to see them bend more on the video...LOL...the total weight of the truck and load is about 215lbs, now that I finished lining the box the finished truck weighs a back breaking 105lbs OUCH !!! (Someone should have used Alm. instead of steel...LOL...yikes its a tank not a truck!!)
