#261
What ? please write in English .
Also this is the 2nd thread of mine you post this in , what do you mean
#262
Hi again.
In the last 2 month, i collected a huge number of Cat blueprints, with aid of these documents, i built a 3D model in 1:14,5 with every little details - Some of the inside mechanics are still missing, but they will be done shortly. Steve, before going further i will make a new thread for it, but if you don't mind, i share the results here: https://www.behance.net/wip/316985/659439 PS ederson wrote in portuguese, and means: Congratulation perfect, and: cool. |
#263
thanks Abel , if i heard it said I would've recognized it but makes sense now
#264
#265
Friend'm from Brazil so I write in Portuguese! and I meant in the first post congratulations and perfect in the second post I meant cool!
#266
Nice loader looks like a mean digger. I like the weight.
#267
finally got the proper lift hight
and no more bolts for pins ![]() went from just getting over the sides on the mack (11") to getting 16" ![]() ![]() ![]() pins : process in order from lathe to finished on the mill . ![]() ![]() ![]()
#268
man what a #####
the lil keepers
#269
Always great to see the 990 progress. The pins and locks look spot on Steve.
I think the broken keeper is perfect! I look at a pin like that it tells me, that one went dry seized in the bearing and the pin tore the lock off and was repositioned after repair. ![]() ...another touch of realism![]() Mario |
#270
Great job Steve looks real good. Ed
#271
That's great way to make those pins!!! I've been thinking on how to do such. Sometime in future I'm going to use your idea and get rid of the c-clips I'm using on pins. I tried to make the flats undersized and press pins into but just not enough material to make tight enough and reliable. And loader looks great!!!
#272
The pins came out nice and the loaders looking better all the time, but what I really like is the jig you made to mill the pins! Nice job! Sometimes the set ups harder than actually making the part.
#273
[QUOTE=ihbuilder;108228]man what a #####
the lil keepersJust wait a few years when you can't see and your hands are shaky and then try the little parts. Hopefully it won't happen to you but enjoy things while you can. Nice touch on the detailing of the small parts. These things make a model.
#274
Steve,
Nice detail!!! I agree, normally it takes longer to setup a part than run it. |
#275
Great work on those pins, Steve! 16" of reach makes this Cat a monster!
Nathan |
#276
nice build but noticed u steal haven't done the up grade to the tires barn hausen modellbau might be a good answer he has a large selection
#277
. I tried Barnhausen directly with no reply . I was hoping to have them for this week end There was only 1 size I saw that was close .
#278
So what's the bore size of your new lift cyls?
#279
#280
holy jeepers looks like I'll get new tires after all
| Currently Active Users Viewing This Thread: 12 (0 members and 12 guests) | |
| Thread Tools | |
| Display Modes | |
