#581
![]() I will come see it in person if you bring it to any shows/meets. I suspect you are going to have to disassemble for transport
Premacon 956 ordered. ETA late 2016. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. The waiting games are real. |
#582
I don't disassemble this machine to move it. I bought an enclosed trailer and leave the boom up. I found this is the easiest way to transport it. |
#584
Found this video someone took at the spring 2013 Brownsville.PA show. There's a big rock in front of the dirt pile that I was pulling around but the camera man didn't get any footage of that. Not sure just how much it will pull. Never wanted to break it finding out.
![]() http://youtu.be/kkm5_hAmHIo . Last edited by 9W Monighan; 08-20-2013 at 12:43 AM. |
#585
Nice video steve-if that big rock by the dirt pile is the one you were moving I would say that is a 100+ tonner in the real world (maybe more). Quiet impressive! The video shows good close-ups of the internals of the model while it is working. Looks like it was working flawlessly as always.
#586
Here are a couple videos taken at the Cabin Fever Expo last weekend. Dragline worked flawlessly
Still no more progress due to more important things...work. http://youtu.be/VhABOy8UHAo http://youtu.be/VhABOy8UHAo Last edited by 9W Monighan; 04-17-2014 at 10:19 AM. |
#587
Steve-looks like the 9W was working great as always. To me the dirt did not seem to be good for R/C models. Was there big rocks throughout the dirt-pile? I guess you work with what you have. Nice videos.
#588
Tom , the moisture content was higher then last year . Perfect for compacting
Which in turn , when compacted made it hard for my loader to dig effectively .
#589
That makes sense steve. I couldn't tell about the moisture but I could easily see the big rocks and also a lot of smaller rocks which it seems would make it hard on the smaller models. The dragline seemed to handle the rocks with no problem but I would like to see some video of how the other models worked the pile. I understand that you modelers have no choice in the dirt that is brought in. You just dig and make it work. Looks like a lot of fun.
#590
Steve,
Did the spring pike show happen this year? I did a quick search here but did not see any posts. I just downloaded a time lapse app on my iPad and it would be cool to get a complete day recording of the dig. Would be cool to watch the dirt pile grow as the weekend progresses. I'm planning to come to the summer show again this year if I'm not otherwise committed, I assume you are going to that one? Jim D |
#591
The show was May 10-11 I put a link to someones picture they took. Search under "Brownsville show pictures" in the general discussion topics. Hope to see you and your wife this August. Should be a great turnout. |
#592
Steve,
Here is the time lapse footage walking to to job site August 2014 Pike Show. http://youtu.be/1V7LJMArOVA Jim |
#593
A little update on a new acquisition for the 9W. Had a chance to get the controls from a machine being scrapped. I had an idea to get the whole cab but after the scrapper cut if off, it turned out to be much larger and heavier than anticipated.
~12,000# 14'Lx 11.5'H x 9.5'WSooo we took the master switches and foot pedals. Wasn't very easy though but now I have them. I plan on wiring them to my machine so I can get the old time operators to give it a try. Most don't want to use the radio used now. |
#594
That is going to be amazing when its done... just when you thought it couldnt get any better, you set the bar even higher... great job..
#595
Ah good you finally got it . They're from the machine out my way ?
#596
I hope you got the chair as well!
Kerst |
#597
Got it Kerst. The seat is out of a newer truck,"air ride" but it's pretty crusty.
Notice how heavy duty the original mounting plate is for the seat. It must weigh around 150 lbs. It would swing out of the way of the two master switches so the operator can get up from the seat. The swing pedal assembly is very heavy. I need to put it on the scale to see. That this was a real PITA to pull up through the floor after it was cut loose. The floor is made of 1/4'' plate.
#598
That's gonna be cool! Two questions: what is the third lever on the far left for? Propel? And is the doohickey on the back of the left console a compass? I can see where a compass could be handy to make sure you walk in the desired direction since you're facing the wrong way. Point the machine where you want to go, take a reading and then swing 180 degrees from that.
#599
The box with the dial is an indicator for the walking cams showing the position 0-360 deg. so the operator knows when they are at top dead center so the machine is clear to swing. There is also a bell mounted to the right hand console not seen in the picture that will ring when the hoist lines are near the point sheave. Very important while digging at night dusty or foggy conditions when he can't see the top of the boom. |
#600
I cannot open the pictures on post #593. Anyone else have this problem?
| Currently Active Users Viewing This Thread: 34 (0 members and 34 guests) | |
| Thread Tools | |
| Display Modes | |
