#301
Oh and I used some grommets from my favorite (if u need a tool cheep to work a few times) store , harbor freight. Cut them in half , they will make great trim pieces from metal to part.
#302
![]() ![]() First coat on the steel parts. Have to get some more self etching primer for the alum stuff. I'm going to try and get the painting stuff out of the way before I hook all the hydraulics up. I'm pretty confident I have all the hoses and wiring routed so no more machineing should be necessary. Just hone and polish cylinders and the wiring. But it's always the little things that take the longest. Like I found out from test running that I need a tad bit more clearance for the wheels.
#303
![]() ![]() ![]() Primed and first coat on.
#304
Cooper, your parts looks great all painted up. I was wondering what you are going to do for cab windows. Your first run video is great. The D11 does seem a little slow, but maybe you could bump the battery voltage up a bit and pick up some more speed. I don't think I'd worry about it to much, unless a little extra speed for reversing after a pushing a full blade forward and going back to do it again might be helpful.
Nathan |
#305
Thanks, for the windows I'm going to use vinyl. I have a vinyl cutter so clean lines and any shape is no problem. Only problem is the color. If I keep the cab yellow then black windows. But I like the two tone cats, yellow with black cab and top of hood. If I go that way possibly grey?? I don't know how that will look. Haven't got that far yet but will have to look and see what color I have. Would hate to order a whole roll for just six inches. I do have a masking vinyl that is a little transparent and grey. That may work. I'll post some ideas as I go.
#306
#307
Question, it's pretty oblivious to me but just wanted to be sure. On the cylinders, for the hose fittings to properly seal should I machine a flat spot where the threads are? I'm thinking with the plastic sealing ring on the fittings they will need to have a clean flat surface to seal properly. Correct? I'm onto finishing up with the hydraulics and clarifying all those little details that seem to drag on a build.
#308
#309
Looks great...I think you have a perfect scale speed. Can't wait to see how it looks with the new paint
#310
![]() I did put a wrench to these, very light on the torque. Figured I didn't want to chance stripping and if they leak then I can tighten them easily. ![]() These fitting are the ones in question. Beings how the cylinders are round I am thinking I need to have a flat mating surface for the elbow plastic sealing ring. I never messed with these small fittings and still not sure on sealing. My thoughts of having 120-140 psi pressure in the system I should have flat and as insurance some sort of sealing putty/paste. Like I said I ain't got a clue . Thanks mackattack, I was just thinking a tad bit faster for duplicate passes for reversing speeds. But I'm happy with it and sounds like it from you guys that it's about right.
#311
And I still do have some lazyness in me
. I'm using the bolts that were painted and replacing with unpainted ones where they can't be seen. Save me from having to paint the heads of bolts in another step . Eager to get her dirty!!!!
#312
![]() Forgot the pic
#313
Looks great! Like IH said, just machine a small flat for the washer and you're good to go! I haven't needed to use sealant on the threads but that may not be a bad idea as well.
#314
Cooper I see you had some teflon tape to seal with, do not use that for the hydraulics if it get in there it will gum them up. Ed
#315
Looking good, Cooper! The paint looks great under natural lighting. It must be pretty durable too. The hex head screws have no signs of chipping anywhere, unless you painted them after they were threaded in place?
Nathan |
#316
![]() Some parts I tried to paint as much together as possible. The paint is a couple days old but still not fully cured. I have been using dry powder graphite on parts that touch as a lubricant and to help keep the paint intact until fully cured. So if it looks dirty on the track parts that's just graphite powder. ![]() And assembly is slow as some things need to be adjusted for the layer of paint. I tried to make certain areas loose tolerances as I've herd people say after paint the parts don't fit. I have to finish up the hydralic parts and paint them. Still waiting on radio. As I really don't want to do all that programming just to redo it when radio comes in.
#317
Cooper you are coming along nicely no sense in rushing things now and making a mistake you have created a excellent model. Ed
#318
Yes and thanks. Oil filter is one of the little things I need to get yet. I am remaking the hose fitting piece for the top of the blade lift cylinders so both black hoses come downward from top. It's still a bit before I get oil in the tank. All those little things,,,, it's like death from a thousand paper cuts!!!
#319
![]() ![]() I got another order from premacon. I was wondering why it was taking so long. I recieved an order from them that I placed after this one. By the looks of it I think it got stuffed in the wheel well next to that little boy!! I know it's not premacons problem but I only got one container of oil (paid for two). That's in the trash somewhere I'm sure. Does anyone know what kind of oil they use? Pretty thin I just don't know what weight oil it is, that I could buy locally.
#320
What a thing of beauty! Paint really makes it come to life.
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
| Thread Tools | |
| Display Modes | |
