Old 07-07-2014, 10:59 AM
Default Re: Volvo A40F
Originally Posted by thercfreak2012 View Post
Are u gonna start on the chassis now
Yes, any day now
Here's the tandem axle cross stay bracket
Old 07-07-2014, 11:27 AM
Beautiful work as usual Ari. Where do you buy your scale hardware from?
Old 07-07-2014, 12:57 PM
This is my source for scale hardware: http://knupfer.info/shop/
Old 07-09-2014, 05:43 AM
Does any of you guys know the RAL code for the Volvo construction machine yellow ?
I think the color name is Taxi yellow and the Volvo's own number is 62.
Old 07-09-2014, 05:55 AM
I got the axles joint with the balance beams
Old 07-09-2014, 03:36 PM
Crazy progress ari, looks awesome as each update!
You can get Volvo paint from the local Volvo dealer, in different sizes and types of canisters if I don't got it all wrong, saw them last time at the Swecon dealer here in Sweden.
Old 07-10-2014, 01:08 AM
ricm ricm is offline
nice - even got roller bearings on the balance beams
Old 07-10-2014, 03:25 AM
nopgc nopgc is offline
nopgc is on a distinguished road
Nice tires. Where did you got tires?
Old 07-10-2014, 07:08 AM
They are from Premacon: http://shop.premacon.com/product_inf...roducts_id=472
Old 07-11-2014, 10:56 AM
I started to make the suspension a-frames:
Old 07-11-2014, 05:37 PM
apfubar apfubar is offline
Wow...
Totally brilliant!
Old 07-13-2014, 11:31 AM
I got the a-frame pivot brackets done.
It seems now that I must change the middle axle for the version that has raised
input/output shaft to get more clearance for the drive shaft
The original has that kind of middle axle too.
Old 07-13-2014, 03:05 PM
Yeah, I was eyeballing your drawings & assemblies & was beginning to wonder what interferences there might be with the driveline.
New parts to see everyday, you seem to be moving forward quite quickly.
Old 07-13-2014, 03:21 PM
It's very hard to predict all suspension movements and it effects to the drive line before you actually build it
There's not much extra room there so there might still be a few nasty surprises to come
Old 07-13-2014, 09:18 PM
Hey that diff in the last picture is what I am after! Well I need two I guess...
The suspension parts are looking great Ari! Did you ever get the TIG welding figured out?
Old 07-14-2014, 06:29 AM
I'm still struggling when I try to weld thin plate to some thicker part, I can't get the thicker part hot enough before thin one melts away
Old 07-15-2014, 05:46 AM
Apidabi Apidabi is offline
Apidabi is on a distinguished road
I had this same problem with my A30c 1/16 scale. Totally impossible to build as the real one.
Old 07-18-2014, 10:27 AM
shantiago shantiago is offline
shantiago is on a distinguished road
impressive metal work
Old 07-18-2014, 03:28 PM
Pippoe Pippoe is offline
Pippoe is on a distinguished road
Beautiful truck so far!! Applause!
Using that new axle should make the truck much more durable. Since the shaft passes through the differential of the middle axle the current axle has to withstand the load of both axles.. The axle with the bypass (provided it actually is a bypass) distributes the load equally onto both axles. Should be much better for the drive train..
Cheers
Pip
Old 07-18-2014, 10:07 PM
doodlebug's Avatar
Have you considered something like muggyweld for the Un tig-able stuff???
http://www.muggyweld.com/
Cheers, Neil.
