| Mechanical tech This is for the mechanical parts of a model. Gear reductions, Axles, Transmissions, General drive line |
I'm trying to get an idea of what you guys would recommend for a transmission for my Tonka conversion. I have a stock Tamiya motor and 3-speed transmission, but I won't have enough room inside the cab to use them.
I'm looking for something I can use a 540 motor with, that is shorter in length, height, and isn't too expensive.I haven't had much luck with the vendors sites, when it comes to price. Thanks, Rob |
Rob check out RC4WD for a transmission they have a 2 speed that is fairly compact. Ed
HD semi version (new) http://www.wtbcar.com/shopping/index...product_id=203
what I have in mine - http://www.wtbcar.com/shopping/index...product_id=154 or try a rc4wd dig tranny?
Ed, that one is on my list, but a little more than I want to spend. I do think it would be a great fit though.
I've also been looking at the RC4WD planetary transmissions. If I coupled a 16:1 with a 65t motor, I would probably have all the speed I needed.
Is anyone using one of these? |
A bit different approach here - but take a look at some of the robot shops - they carry electric motors with gear reduction units already attached. sometimes they are more affordable. but they are generally more compact.
Izzy, that's a great idea, and I will start looking into that option right away.
I too would suggest looking at the planetary style gearmotors. You might even consider robbing such a set-up from a cheap power screwdriver, or an old cordless drill. You could run a rear axle, using a driveshaft with that set-up, or you could also drive the wheels directly off the output shaft of the gearmotor, although then you will one motor for each wheel you wish to power.
Nathan |
Servonaut planetary gearmotors are strong, quiet and compact. Over here in the old world a lot of folks that are into RC trucks, quickly throw out the noisy, backlashing Tamiya 3 speed, and it's motor which is more suitable for Formula 1...Most popular is the GM32U370, 7.2 V and output speed of about 370-400 rpm. (The speed with a standard 1:2.666 differential with equal 2'nd gear on a standard Tamiya 3 with a motor turning 6-7000 rpm, as of e.g an LRP Truckpuller) Will give a speed of 1.5 mph, which many find very suitable, and have no trouble dealing with total weights of 50-60 lbs. there is also the GM32U450, 12 V, which got double power. Costs about 100 USD. I don't know if there are any dealers over there, or what shipping cost from Germany. Will be cheaper disassemble a battery screwdriver, if one comes over one with a suitable rpm. About 150 rpm on the wheels of Tamiya 1:14 size tires gives the 1.5 mhp speed..
My vote would be a pre-assembled gearmotor as suggested by Izzy - absolutely right to look at the robot parts suppliers....
try http://www.technobotsonline.com/ these guys have a HUGE range to suit pretty much anything. And pricing is pretty good |
I have a 14:1 on the way from korea. I'll see what it's like when it gets here. might be too slow at 14:1 for drive motor but it is intended for my lift. there is a lower reduction to which might be what the RC4WD ones are.
Thanks.I've seen a 1:5 ratio one also on eBay.I'm running a 45t motor from rc4wd.Appreciate you giving me your input.
A 4:1 or a 5:1 is a good auxiliary reduction box to add to another main transmission, but you'll want a lot more reduction than that, if you are thinking of replacing a Tamiya 3 speed with a more compact planetary or spur gear transmission.
Nathan |
Ok.Thanks.I'm looking for something a little more compact to replace the 3 speed that I have in my KH.Looked at the links on here and was thinking of running one of the robot planetary ones.Just don't know which ratio to go with.
Hi All
has anyone fitted a 2 speed either in front or behind a 3 speed? if so what did you use? |
can you or some one tell me where i can get a drive shaft center support bearing, thanks oldracer
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
