Old 09-20-2014, 09:17 PM
Default cat D6T 6 way blade
This started as a Izzy dozer which got me some of the base components .
somewhat how it started
tractor almost finished with the mods , still a ton to doo .
I made a ripper for it
next the blade assembly
now I did go a lil crazy on detail here
There's a thickened plate welded inside for threading where the top link attaches and the ball socket will attach .
Old 09-20-2014, 09:22 PM
Claus's Avatar
Claus Claus is offline
Default Re: cat D6T 6 way blade
Wow, that's nice!
Old 09-20-2014, 09:46 PM
PaulNZ's Avatar
PaulNZ PaulNZ is offline
You are a fantastic engineer!
Nice work on this dozer, it should also perform well being so heavy, dozers need good ground weight for tractive force
Very nice, I will follow this build
Old 09-20-2014, 10:37 PM
Looks like you were doing some heavy pushing already judging by the bent grousers. The attachments look great as usual and I don't want you to take this the wrong way but is it bad that I am more intrigued by what might be in the background? I know you are sitting on another set of expensive tires so I am guessing this will be their home?....
Keep up the great work! Starting on a dozer very soon myself so this helps me get motivated.
Old 09-20-2014, 10:45 PM
Good eye Reg , there's actually 3 of them .
Thanks all dozers are my passion . They say I was born in the seat of 1 .
Paul , yes the more weight the better .
Old 09-20-2014, 11:52 PM
Cooper's Avatar
Cooper Cooper is offline
I too love all the dozers. This looks great!! Can't wait to see more!!
Old 09-25-2014, 10:29 PM
I wanted to get this lower (ball joint) done before starting a run of wheels but bizz iz bizz . So finally , last night and tonight ( about an hr each ) it's done
yea, a lil chatter on the 1 piece ( screwed up feeds & speeds ) it'll sand out . I did it in 2 setups with a manual face off on the back side . Next pic shows firgelli , only a temp rig up for this wknd .
Old 09-25-2014, 11:45 PM
Nice job! Cant wait to see some videos.
Old 09-26-2014, 12:57 AM
PaulNZ's Avatar
looking good!
Old 09-26-2014, 06:21 AM
Kingcam2's Avatar
Kingcam2 Kingcam2 is offline
Nice work so far ihbuilder, one day I want to order one of the Izzy Bulldozzer.
Keep up the good work, I can't wait to see the next update on your build.
Regards Cameron.
Old 09-26-2014, 10:37 AM
kaptain Jack's Avatar
I want one to.
Old 09-26-2014, 11:31 AM
modelman modelman is offline
Hi steve-I am always impressed by you and 9w making parts from steel. I can't do that!!! I just ruin tooling. I guess that is the difference in a machinist and a backyard-hacker. Guess I will stick with brass and aluminum. Your dozer looks good and I am sure it will work good.
Old 09-26-2014, 09:24 PM
thanks guys .
Tom, I love cutting steel . Aluminum and I have a love hate relationship when I started with it on the cnc equip.
I took a break from polishing :blea: and pushed some hard ground with it Plenty of power . I'll see if I can doo a vid on sunday . tomorrow will just be rubber pit
Old 09-27-2014, 12:42 AM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
Your going to go play in crumb rubber? I thought you swore that stuff off.
Old 09-28-2014, 09:19 PM
well you know this thing needs to be babied sometimes it will rip its grousers off in the dirt
Old 09-28-2014, 09:39 PM
I did get some crappy phone vids with the phone in the cab and some machining parts . but I might not live long enough till they upload
Any how , the boss told me to take time for myself so I finished up the bosses on the blade ( tilt and angle ) . I'm trying new software , so it's a pleasant go so far compared to the hobby grade package I started with
angle boss model
parts
yes i doo doo some manual machining, simple hole
spot welded in place
tilt boss model
part I kinda like the plasma cut look . A lil filing or sanding and it disappears
outside pushin
Old 10-19-2014, 08:03 PM
Izzy's Avatar
Backyard enginier
Lookin Good Steve. No fartin' just seen one of these the other day. Looked really kool up close. Doin' great.
Izzy
Old 10-19-2014, 09:36 PM
Thanks Chris , we got a couple runnin around here . Picking up steel yesterday at surplus yard yesterday there was 1 cleaning up the pipliner's mess I almost got close enough to see how cat connects the lift cylinders while 4 guys in hard hats changing the cutting edges ( 1 doing the werk and 3 BSin ) gave me a funny look . proly thought I was gona yell at em for werkin under the blade with no support (idiots ) If dad caught me doin that back in the day . anyhow , I'm just improvising
Old 10-26-2014, 09:22 PM
I worked on the tank and ROP this weekend . I didn't fuss on the inside of the tank , not that it will be seen .
the holes in the center are for spot welding
I need to cut the bolt plates for the bottom of the ROPS then tig em on like the mating plates on the tank .
Old 10-27-2014, 10:31 AM
Looking good Steve. This should definitely add some weight for traction too!
