Old 05-20-2014, 11:24 AM
JAMMER JAMMER is offline
Default Re: Liebherr 922
http://www.der-getriebedoktor.de/sho...l.php?kid=3121 If you call or email the owner he is very helpful and he speaks english. Ed
Old 05-20-2014, 12:45 PM
SmallHaul's Avatar
Thanks, i thought you had drill and tap the cylinders to increase the fitting size but, didn't know for sure.
Scott
"No load is too Small"
Old 06-17-2014, 04:42 PM
calum_scania's Avatar
calum_scania calum_scania is offline
calum_scania is on a distinguished road
A short video made today
https://www.youtube.com/watch?v=Ije7...ature=youtu.be
Calum
Old 06-21-2014, 05:25 AM
Originally Posted by calum_scania View Post
Nice video!! I like how you put in different angles of view.
Old 06-21-2014, 01:35 PM
Thank you, a short video with plenty of angles
Old 11-23-2014, 10:40 AM
thebigo thebigo is offline
Just an Idea, RC4WD has 2mm Hose, this may work, but Joe would Know better than I.
Old 11-30-2014, 01:49 PM
Hello everyone I'm trying to do this on my MC20, Its to contol functions on a digger, normal mode for digging and the sliders control the tracks. Then a switch setup to change the right stick to control the tracks. I have set up 6 mixes which seem to be working, but using the ELE towards you and AIR to the right is still moving the servo's I don't want to move (these work fine on the other direction) I there something simple I've done wrong?
Here's a video on a Spektrum radio which I'm trying to achieve
https://www.youtube.com/watch?v=09fe49ply7o
Many thanks Calum
Old 12-03-2014, 08:45 AM
ptebbe ptebbe is offline
ptebbe is on a distinguished road
Calum-
What you are trying to achieve is entirely do-able on your DX10. You simply have not configured your mixes completely right.
This requires 2 mixes for each stick direction, both turned on by the switch. The first mix has to completely negate the original control commands...set up the mix to be completely opposite of the original control. You've manage to set up your mix correctly for up and left, but not down and right. A simple tweak of the mix parameters will solve this.
This is my cancelling mix: Ele==>Ele -100% -100% and Ail==>Ail -100,-100
The second mix then adds the control to the stick that goes to the track drive.
(For some reason that I do not entirely understand, I had to set mine up such that the original Ele and Ail channels controlled the tracks, then the mixes over-rode it and mixed control to the dig-arm. Otherwise the drive motors would not stop even when the sticks were neutral.)
hope this helps.
Paul
Old 12-03-2014, 04:09 PM
I've just sorted this tonight, I was a combination of 2 servo's needing slightly adjusted and having the values set to 150% instead of the correct 100%
Calum
