Old 12-30-2014, 02:58 PM
rc_farmer's Avatar
Master Builder
Default MorePower Hydraulic
I received my morepower hydraulic pump and valves yesterday.
Two nipples broke off, but i was able to drill them out
All out..time to drill and tap for 5mm nipples
I drilled and tapped both sides of the block. It can with only one side tapped.
Be sure and remove the valves before you drill or tap the body, clean out all the metal and then reseat the valves in the same holes as they were removed....set them with lubricate too so as not to scratch the seals...use thread locker on all the nipples
You may need to put some thread locker on these 2.5mm set screws as well
Works really good this setup
Giving up is not an option!!!
Rob
Old 12-30-2014, 04:01 PM
Default Re: MorePower Hydraulic
Good job Rob . Those valves work so much better reported .
Old 12-30-2014, 09:25 PM
rc_farmer's Avatar
Master Builder
I love these valves, gonna order another set just for GP
Rob
Old 12-30-2014, 09:42 PM
Don't buy them out on me !
Old 12-30-2014, 09:48 PM
woodhog's Avatar
woodhog woodhog is offline
Im glad that you got this figured out. I heard the morpower pump and valves are nice. What kind of pressure you think it will do and what ml volume is it?
Woodhog
Old 12-31-2014, 11:44 AM
Dieselchopper's Avatar
I have been dealing with more power for over a year. The pump is strong, be cautious with your pressures as I have split lines. The nipples are weak at the transition point from m3 to instillation nut. Have broken many. They are good at replacing things if you ask. I am a Canadian dealer for them. But most cases it is still cheaper to deal direct as I get no different deal at this time. I will be running their system in most all of my future builds. Happy building!
Old 12-31-2014, 03:38 PM
rc_farmer's Avatar
Master Builder
Chris, i don't kow the pressure yet, still need to get a gauge. I also ordered a PRV from rc4wd as i think the one that came with the excavator is bad. I talked to Steve yesterday....i disconnected everything from that PRV and could not blow any air thru it. The reed stem, which is cone-shape with a rod surrounded by a spring sticks so tight in the opening, i had to jam a screwdriver into the outlet to free it.....that what was causing the pressure to burst line when we did hook it up correct.
I have seen these pumps modified to accept brushless motors as well, i will figure that out
Oh yeah, they ship fast too. less than 10 days from order to doorstep
Rob
Old 12-31-2014, 03:55 PM
woodhog's Avatar
well at least you know what was wrong with the other system
Woodhog
Old 12-31-2014, 04:58 PM
bigford's Avatar
bigford bigford is offline
how big is the pump? I need something for the day cab dump with a wedico cylinder
was looking at this or the ums pump or the one semi joe has on ebay.
I really want something I can hide in a fuel tank.
Old 12-31-2014, 09:11 PM
rc_farmer's Avatar
Master Builder
the complete assembly is 5 3/4 inches long from the flat front of the tank to the motor leads.
the pump assembly is 4 1/2
Rob
Old 01-01-2015, 02:00 AM
Kingcam2's Avatar
Kingcam2 Kingcam2 is offline
Hi Rob,
Sorry to Ask, but I just got my Kat Excavator and I just wanted to know where you got your morepower hydraulic pump and valves from, as just in case Kat valve bank give me problems, as a mate of mine Kat valve bank keep leaking oil on him?
Regards Cameron.
Old 01-01-2015, 12:40 PM
rc_farmer's Avatar
Master Builder
http://www.morpower.com.tw/
I paid with paypal,
Rob
Old 01-01-2015, 01:46 PM
bigford's Avatar
they also have a ebay store
http://www.ebay.com/itm/271719171841...%3AMEBIDX%3AIT
Old 01-03-2015, 07:18 PM
rc_farmer's Avatar
Master Builder
Success!, I think i have figured out the hydraulics. Here is a quick video of the setup. I would highly advise that anyone who has the Morpower block to pressures test all the fittins and replace all the 3mm set screws before installing in your machine. I have replaced 5 of them that was leaking with 3mm caphead screws.....no more leaks.
Rob
Old 01-03-2015, 07:21 PM
You're not running their pump though? RC4WD pump in that video?
Old 01-04-2015, 01:53 AM
rc_farmer's Avatar
Master Builder
That is a Morpower valve block. I bought that pump as an extra when i bought the setup. The original pump is a 540type brushed. I am going to replumb everything once in the excav. I am also going to use a different type tank.
Also, those servos are junk. The kill the rcv'r if more than two are plugged in, Steve said to use Hitec 85mg which i will p/u on monday.
Rob
Old 01-04-2015, 09:13 AM
Rimrock Rimrock is offline
What pressure can it be operated with? Leakage issues?
Old 01-04-2015, 02:26 PM
I was just wondering if you used the RC4WD style pump because you didn't like the Morepower one or???? I almost ordered a pump from them a while back but chickened out. Just wondering what your thoughts were on it compared to the RC4WD pump? I would like to buy a pump for my log skidder and it needs a fair amount of volume.
Old 01-04-2015, 02:55 PM
rc_farmer's Avatar
Master Builder
I hope to have a pressure gauge of some sort in the very near future, then i can get some accurate readings of pressure.
Rob
Old 01-04-2015, 05:32 PM
That's great, will look forward for some real life test results) I notice it is written 30 bar / 435 psi as max pressure at their homepage. Looks better engineered than the chineese crap...but never know before tests has been done..
