#361
![]() ![]() The motor in the last pic was harvested from an old massage chair. On 12v it runs pretty slow, might be perfect for this. The one roller will be the drive roller and other will be tension roller.
#362
![]() ![]() ![]() ![]() ![]() ![]() ![]() Got back into the swing of things. Have to look up some 1:1 pictures for loading funnel and some kind of elevation or wheel system.
#363
Nice to see you back in the groove RW.
Your conveyor is looking super sweet! Can't wait to see it with rollers installed, a fresh coat of paint and some dirt on the move. ![]() As a suggestion for support legs, how's about using a screw drive like Regs dump boxes as a way to power adjust the conveyor height to whatever you want or need? I'm still along way from building a funnel for mine but my first attempt is going to be like what RVJim has posted. Seems simple enough and effective. I'd add the link but for some reason my IPad won't copy paste links on here anymore?
#364
http://youtu.be/BSS0AAxQkpE
It works!! My wife saw what I had been building and asked what on earth do I need a conveyor for? And I replied " to convey stuff!" Duhhhhh
#365
That is way cool ! Mike
#366
Beautiful job RW! That thing runs straight and smooth as silk
Speed looks great also. What RPM did you go with? I'm very curious to see what kind of angle you can set it at and still carry material. Such a nice job on the rollers and getting a nice dish to the belt. I bet it will work great! Set that beauty to about 60 degrees, throw some dirt on it and let's see what happens.
#367
Rpm? Uh,, yea, don't know, lol,, the motor was harvested from an old massage chair and sprockets are a couple teeth different. That was running on 7.2v. Originally I planned on 12v but without adding a trimm pot I just hot wired that 2s pack. I haven't got into much of the electrical part yet. I'm still planning on running 12v with a pot for speed control. I'll get the rpm of what the video was running tonight and post so we both will know
. 60 degrees ehh? I'm not going to make this power elevation but will try and make it adjustable to max allowable incline. If I can get material to stay at 45 I will be happy. Might even make it on skids with detachable wheels so I could use a machine to move location of spoil piles. To be honest I never thought about much more than getting the belt moving straight . Now some more planning !!!and some sort of funnel too. Would be cool to have this in a pit so the dozer could push material into.
#368
Good Job bro, im digging it!
#369
Looks good can't wait to see it moving dirt
Woodhog |
#370
Your drive roller should be pulling the belt. Looks good, runs quiet & smooth.
I think you'll be hard pressed to get much more than 20° without too much rollback.
#371
nice conveyor, have you thought about gluing some teeth to the belt to allow you to have a higher incline if need be.
I found on mine (4 feet long)about 15 degrees was the max before the rocks started to roll down hill, also if I slowed it down you can go a little steeper. cheers andy |
#372
#373
![]() I was wondering if drive roller must be on the top end? The way it is now all the belt tension is on the bottom which allows the top to have slack and maintain that curve or cupping effect? I guess with heavy material trying to push up a loose belt won't work though..... Ok. Never mind ![]() I like Lou's idea using the leading edge of a wiper blade as paddles or teeth on a belt. Just not sure how well they will adhere to the treadmill belt? |
#374
under the deck with height of about two feet.
#375
good plan.im going to be using mine to feed the screening plant , don't have to build a ramp or pile for the excavator to sit on, just feed the conveyor and job done.
cheers andy |
#376
![]() ![]() Got the wheels on, it can be elevated a bit more. And lowered completely to the ground. I think it may be a bit heavy for a pintel hitch for the dumptruck but I figure that out later. I still have to get some cross braces and under rollers,, ect,, but you get the idea
#377
The 4 inch width conveyer I had in the basement 5yrs ago was at an approx. angle of 17° & I was getting some roll back of larger dirt lumps & rocks. That was the entire reason for originally building the dirt lump crusher -> the finer the dirt, the less that rolled back. The dirt I was elevating was bone dry too!!! it's almost like beach sand.
Moist dirt and crushed rock, I'm sure you could get greater than 20°. Your belt RW doesn't seem to have much stretch & bottom drive will probably work fine for you, but you will have to run the tension tighter than if it were top drive. While you're still in the building phase, I'd recommend that you fashion some kind of brush wiper just ahead of the bottom drive roller to keep out foreign material that would affect your roller's traction or jam it up. I have this problem of fine dirt/dust somehow getting on the inside of the belt of the conveyer that's on my dirt lump crusher, it's a bottom drive with a 5" diameter roller with a 4" width hay baler belt. Even with the conveyer tilted a wee bit, any minute amount of moist dirt that goes through the crusher, moist dirt fines will build up/jam up on one side my conveyer drive roller & stall out the crusher completely. One of these days I'll get ambitious, tear my roadway apart & take that crusher & conveyer to the shop to make some very needed improvements! There's over 200lbs of machine there caked in fine dust to monkey with.
#378
I haven't got to the hopper area yet joe, but it was planning on having some type of loose rubber or brush to guard against rollback into motor/drive roller area. Just not sure yet, I may just cut some rubber fringe as I've got rubber tubes around but no brush type stuff. Well let me go check the wife's bathroom, I may find some brush material
#379
![]() ![]() And that hitch on the dumper may come in handy? ![]() ![]() Finally got some mail , parts to get the hoe up and running. I was home when the mail man stopped. As he handed me the box the valve assembly fell out!! I know him and told him I may be getting in touch as I was not sure if anything already got loose!! ![]() ![]() ![]() But thankfully everything was in the box that I ordered!!! Had a large shift of emotions in a short amount of time today
#380
Great timing! You're just about finished project conveyer & now parts arrived for project excavator.
![]() The box for my hammer was tore up like that too , the way the hammer was wrap in bubble wrap it couldn't fall out, but dayum! not much care shown to it during its journey.
| Currently Active Users Viewing This Thread: 130 (0 members and 130 guests) | |
| Thread Tools | |
| Display Modes | |
