Old 01-19-2015, 09:11 PM
chris deacon's Avatar
chris deacon chris deacon is offline
chris deacon is on a distinguished road
Default Re: JBC limited NZ
Cheers for the Help Andy. I bit the bullet and with my teeth gritted i bought some from RCBitz here in the uk. Cost about £36 in the end and thats enough for 2 tank fulls.
My oil guy here at work is going to find me some equivalent hydraulic oil as i wont be paying those prices again lol. Got two 6400mAh 3S1P 30C coming from Hobbyking too and the 4200xl should be here between 5 and 11 days time..Woohoo
Old 01-20-2015, 12:53 AM
nice need picts in the dirt.
i spoke to several suppliers for work and they worked out what i need, 20l bucket is a bit much, but with three hyd models it will , still last a long time.
$30 from rc4wd for two tank fills is way too much.
talking to a fellow dirt bike rider he suggested motor bike fork oil as its pretty close to the tellus oil and should work and you can buy it in 1 liter packs. and its cheap.
cheers andy
Old 01-20-2015, 01:07 AM
cheers andy
Yeah thats £36 not $36 so its even more lol
Old 01-20-2015, 03:39 AM
pyrosrock pyrosrock is offline
pyrosrock is on a distinguished road
Im uesing the tellus 15 equivalent which is a dte light by mobil as its free and avaliable at work.
the hydraulic guy here at work recomended it for the application but he insisted on a test drive just to make sure it was ok, that was almost two years ago. So I can say the mobil oil works, no leaks from ram seals.
lf you use an oil that is too light it will cause issues and the same if its too heavy.
got a quote for 20 liters yesterday $120.00 , its the smallest container they sell.
should last a long time.
I am using 15 weight motorbike fork oil in mine, it is essentially the same stuff but foams a little easier i believe. But you can pick it up in 1L bottles from any auto shop
Old 01-24-2015, 07:30 PM
all right update time.
have sorted my issues with the 4200.
I had a leaking pump seal, new pump sorted that.
I played with the radio settings and made a complete hash of it.
read the manual, did some more playing and fixed it. slowed the slue and speed the main boom drops
had a small problem bleeding the system, worked out one of the problems was I put the tank back in the wrong way around and the suction line was fitted to the return of the tank, so the rams would move , fill the tank enough to force oil into the pump then it would run dry again!!! MUPPET!!!
still , im learning and wont do that again.
radio is pretty easy do use now, so will play around a little more with the settings.
had to test it all out so dragged the screening plant outside and had a play.
http://youtu.be/71ClQVuDoD0
Old 01-24-2015, 10:28 PM
this link should work
https://www.youtube.com/watch?v=71ClQVuDoD0
Old 01-24-2015, 11:15 PM
last play for the day, a quick test of ripper 2.0 and a bit of practice swapping buckets on the quick release.
found a switch on the radio.
it kills 4th valve and slows stick movement, very handy.
would have saved me a lot of grief messing with the radio settings.
any way video time.
http://youtu.be/itvxOmZ6xqk
Old 01-25-2015, 07:28 PM
after finishing cooking the BBQ the wife made a small suggestion " when are you going to clean up the mess you made with your excavator"
now being the conscientious bloke I am, I skipped out of doing the dishes and grabbed a beer and cleaned up the play area.
heres the result.
http://youtu.be/KH8wnOORwO8
Old 01-27-2015, 03:03 PM
any way video time.
Which switch was that Andy?
Old 01-27-2015, 04:00 PM
It's the "mix channel" switch he's referring too, turned off will slow hyd flow to a snails pace b/c 4th valve doesn't move/remains open.
Old 01-27-2015, 08:54 PM
that's the one Joe, found it by mistake.
good for practising the bucket swaps, I need some more reading time to see if I can do something with the slew as its quite jerky and smooth small movements are quite a pain.
I am wondering if a better esc and motor gear set up will fix the problem, or can it be slowed on the radio, by that I mean the acceleration of the motor.
the mix channel switch seems to only affect the hydraulics , only noticed it as my sound card is controlled by the forth valve( engine revs ) but dosent seem to have any effect on the rotation.
time to get the radio manual out.
cheers andy
Old 01-27-2015, 09:40 PM
A better esc would be best to try, one with a light to no brake.
The mix has nothing to do with your rotation. You can manipulate your rotation speed & smoothness with the use of dual rates using different values for curves & offsets, and it will help alleviate some of jerkiness, but not eliminate it. Your right/left movements on the sticks are either aileron or rudder, which is which on each side of tx depends on which mode (1-4) your transmitter is set to.
Old 01-27-2015, 09:42 PM
osikasculptor osikasculptor is offline
osikasculptor is on a distinguished road
What I did was screw the dial all the way in on the pressure relief valve then
the dial for that servo can be used to manually adjust the overall pressure/function speed from the radio (mix always off then) This also keeps sound constant- dialed up down manually with pump on or off.
Old 01-27-2015, 10:20 PM
thanks guys,
engine revs , I can set max revs on the signal reversing cable ( small pot on board )
Im more focused on the rotation jerkiness ( if that's a word ), I will try joes suggestions on the radio and see how we go.
if I cant get any joy out of that next will be an esc, the more play time with the radio the more confidant I am becoming at changing things up, also learnt write things down before I change too much LOL.
thanks for the help
cheers andy
Old 02-01-2015, 10:35 PM
thebigo thebigo is offline
Andy, do you have a lot of play in your turn tabel? Because my motor gears went bad on mine causing it to be kinda jerky and then not turning at all.
David
Old 02-02-2015, 06:20 PM
No. Have checked all the possible mechanical issues and everything is good, it is more of an electrical issue . The smoothness of how the motor preforms on the control side of things.
have ordered a few esc's to see if I can take out the choppyness of the brushed motor, if that dosent work maybe a brushless motor will be smoother .
still have a few projects on the go so can use left over bits for other toys, and you can never have too many spare parts.
Old 02-26-2015, 05:58 PM
finally got motivated and installed the light kit for the loader.
had to disassemble the loader to run all the cable's nicely out of the way ( bit of a mission) but worth it in the long run.
indicators work off steering , even got them on the correct side first pop, left is left right is right.
figured out the radio to get them switching on the aux pot at top of radio,
now all I got to do is put her back together and start the digging.
heres a few picts.
no lights
just the cab lights
and flood lights
also has a reversing beeper , but no volume control, that's an easy fix at a later date.
Old 02-26-2015, 06:00 PM
Looking good Andy
Old 03-06-2015, 09:21 PM
had a couple of quite night shifts and started thinking about the dozer, was not ever realy happy with the ripper so I made a new one.
also made a start on a larger bucket for the excavator to deal with loose dirt.
more to come.
cheers andy
Old 03-20-2015, 07:08 PM
had a bit of down time in between wife jobs, so did some earth moving of my own on a smaller scale.
next on the to do list is play with the radio and see if I can get the hydraulics to run a little smoother, mainly in the steering so its not so jerky.
http://youtu.be/z0qhwy-8HZ8
