Old 01-29-2015, 07:04 PM
73blueblazer 73blueblazer is offline
73blueblazer is on a distinguished road
Default Steel excavator build
Hi everyone, my names Justin alittle about me I'm 29 live in michigan and I work as a draftsman so I have lots of mechanical experience. So I've been following everyone's post for the last year and a half and I'm finally ready to build my own excavator. I started with a plastic FastLane toy for my pattern but I realized that's not what I want so I found a cad file of a excavator and scaled it to around 1:14 scale. Then I started with a sheet of 22ga steel but I'm thinking it might be too thin. What is a good gauge of steel to use 20ga or 16ga? I want to tack weld it together and braze the seams together. Polly just use k1 links for tracks and rc4wd for hydraulic components until I can afford to get autocad and out source my machining to my uncle. I also bought a Big Farm dump truck I plan on converting or building from scratch later on. Do you have any recommendation for my excavator build? I will post pics of progress soon as I figure out how to.
Old 01-29-2015, 07:33 PM
Default Re: Steel excavator build
Cad file
Old 01-29-2015, 07:36 PM
22ga bucket
Old 01-29-2015, 08:48 PM
woodhog's Avatar
woodhog woodhog is offline
Looks like you got a good start! The body won't matter what gauge you use just use what you can work with the best The heavier the easier it is to stay in place while digging.
Woodhog
Old 01-29-2015, 08:50 PM
I use 20ga & mig weld with 023 wire... I just got a tig recently, haven't learned to use it yet.
Old 01-29-2015, 09:44 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
I used 22ga for body work ( no welding though) and 16 GA for non threaded structure items. 13 GA and up depending thread type.
First dozer used 11ga for main body just to add weight.
Watch your gage due warping from heat buildup during welding. All thin gages come from heavier hot rolled....
Izzy
Old 01-30-2015, 12:07 AM
Thanks for all the information. Here's my welding cell I made from an old gas furnace I have the hose I stick out the window and have a 6" inline fan I only have my spare room to work in for now till summer time for a garage.
Old 01-31-2015, 02:05 PM
Playing with photo bucket
File Type: jpg 67A40259-81C6-44FC-815A-E2918CDEFB6D_zpsbspzwc8l.jpg (62.6 KB, 86 views)
Old 01-31-2015, 03:00 PM
Rimrock Rimrock is offline
It's practical to build the 'engine house' cover as 1 big piece, that is easily removable for good access. One can have separate smaller hatches/doors in the main cover.
Track sprocket wheels should run about 30-40 rpm. Superstructure to rotate about 10 rpm.
Looking at your sketch, I would maybe get some more clearance between the tracks and the bottom of 'engine house'/superstructure, like double it?
Old 01-31-2015, 04:07 PM
Quick tutorial showing how to use photobucket.
http://www.rctruckandconstruction.co...ead.php?t=4057
Old 01-31-2015, 06:28 PM
Rim rock yea I'm not going to follow it to a Tee I just wanted something to base my model off of I'm not looking for any particular machine this is my fist build ever. I found lowes sells 2 foot x 2 foot 16ga I think I'm going to pick some up tomorrow.
Lil giants thank you it's hard to figure things out on my phone.
Old 01-31-2015, 06:43 PM
Old 01-31-2015, 06:46 PM
http://
Old 01-31-2015, 07:01 PM
While I'm not far in my build would you start with the bucket and boom or the tracks then boom? I don't have any hydraulic items yet I'm affair of building the body too small what's a front to back and side to side dimension I could use? I'm working with limited tools at this time but I want to get started building cause I know the basics of what I need and buy pumps and cylinders as I go.
Old 01-31-2015, 08:25 PM
What size life size machine do you intend emulate...30ton machine, 50ton, 80t?
I use a phone to browse on occasion away from home, but always use laptop to post.
Old 01-31-2015, 08:49 PM
I'm not familiar with the different tonnage I'm think just an average size.
Old 02-07-2015, 08:31 PM
Just wanted to say it's going to be a week or two before I start building I sat down started to price out how much everything's going to cost and I decide cause I want to build multiple vehicles that I should buy some more tools to make it easyier and more cost effective in the long run. So I borrowed money from myself I'll pay myself interest in the end. But I bought 16ga and am happy with the gauge but realized it's going to be hard to cut so I purchased a shear with 12" throat from northern tool. I also bought a laptop and turbo cad 2d/3d so I can design before I build. And I'm thinking about purchasing a Sherline lathe so I can make bushings and hydraulic cylinders ect... So hopefully I'll be building again soon
Old 02-12-2015, 09:33 PM
Got my sheet metal shear I highly recommend to anyone have trouble cutting thick sheet metal I cut a piece of 1/8" thick 1" wide easily I need a better bench for thicker stuff says you can do 1/4" sheet but idk it's 16ga cuts like butter
I got playing around bucket 2.0version 16ga cut with shear only and sanded a little. Now I'm only waiting for cad software.
Old 02-13-2015, 04:35 PM
Started following my print all 16ga so far.
Old 02-14-2015, 06:58 PM
I wasn't sure how I was going to assemble the boom here's what I came up with this morning I built some saddles to get me started.
