Old 03-06-2015, 09:05 PM
Cooper's Avatar
Cooper Cooper is offline
Originally Posted by doodlebug View Post
Glad it wasn't the dog drawing, First Blood!
Lol! If that was the dog cutting skin, I would be missing an arm!! You can see big dummy in the pic with the inspector.
This is what wakes me up every morning at first light,,,, by biting my arm!!!! No need for an alarm clock, every morning , snooze button is his furry little butt going for a flight across room!! Lol!!!
Old 03-06-2015, 09:08 PM
TRUCKMAKER's Avatar
Originally Posted by TRUCKMAKER View Post
You got them all done yet? They're looking good!
Haaaa!!! Still cutting pieces!!! Want to go beat my dog!!! But not as bad as making dozer tracks!!!!!! Lol!!
He'll probably bite your other hand then you'd really be in good shape, let alone what the safety inspector would do. But having the dozer would be worth it!
Old 03-06-2015, 10:27 PM
Cooper's Avatar
Lol!!!
Working on um. Have all the parts and a few extras if needed. Now for some good fumes to inhale before bed, souls have some good dreams!! For these I'm using silver solder, and same for attaching brass rings to trailer frame.
Old 03-06-2015, 10:48 PM
TRUCKMAKER's Avatar
Out of curiosity what are you cutting that brass with?
And I feel your pain, this is what I put up with trying to get a shot at sitting in my recliner!
Old 03-06-2015, 11:04 PM
Cooper's Avatar
I'm using a 30" shear/brake/roll to cut the brass and have a 12" brake that is a little more precise for small stuff.
If it's not a cat biting me it's a dog licking!! I see you have a set of fangs to fight against for your chair!! Lol!! My wife should be very thankful I love her as much because I'm really not that much of an animal lover, one cat and one dog is (well was) my animal limit!! But it is fun to haul the cat around in the trucks!!!
Old 03-07-2015, 03:40 PM
Cooper's Avatar
Got all 22 of the extension supports done, just a couple pics of the process I came up with.
I was using a piece of wire to elevate the plate for a centering lift, it soldered to the brass, I added too much solder.
Turned a piece of aluminum to use for a spacer and that worked for the rest of them.
Had to add more than the usual heat needed as the aluminum jig was acting like a giant heat sink, just took a little longer to get up to flowing temp.
Old 03-08-2015, 03:30 PM
TRUCKMAKER's Avatar
The parts came out great but I realy like the jig!
Old 03-08-2015, 04:36 PM
Cooper's Avatar
Yes I'm really happy with them, after the third one I knew how much heat and where to apply. Then they started becoming easy and looking well!! Now if I could get my welding better!!! I had some stay-bright from Harris welding that I used to hard solder the little brass rings to frame, that stuff works great and didn't need too much heat. I made a 1/8" aluminum shaft to align them and rubbed a tiny bit of oil on the alum as a contaminant to help the solder not stick to shaft for assembly. Have to go to Wally-world and when I get back I'll try and post some more pics of progress. I have been soldering the wheel well parts instead of tacking, I think for the strength the frame will bend before any welds break. Everything is a learning curve .
Old 03-08-2015, 08:24 PM
Cooper's Avatar
I really want to blast this whole thing but my cabinet didn't fit the trailer after wheel frame was attached. Might have to get some dry sand and use the big one at work. Mikem , I know I said I was going to use bass work for decking and not going to use alder, but when I went and looked in the wood pile I found some dark oak or maybe some other dark wood that I forgot it had. I'm pretty sure it's oak. Anyway I'm going to use that and was thinking of using a wood burner to make plank lines and still use one solid piece for each side. Am planning on cutting some strips that will be glued on bottom side to act as a clamp to hold wood down. Only steel I have to do is a couple strips to tack between gooseneck arms on topside for someway to attach wood. I want to make that to be able to give somewhat incase neck doesn't raise completely square. This may end up getting some "weathering " for a paint scheme. Figure a flat/ eggshell black, not too shiny.
Old 03-08-2015, 08:37 PM
bigford's Avatar
bigford bigford is offline
the fact that you have that many drill bits of the same size confirms you OCD!!!
trailer is looking great
Old 03-08-2015, 08:44 PM
Mikem Mikem is offline
How about scribing lines in the oak or whatever with a 1/32 mill cutter instead of burning . I just cut some T and G for a tender for a loco I'm building .100 x .445 which scales out to 1 3/4 x 6 planks . then glueing them all together again for the deck . If you can find out if it's white oak it would be better than red oak . When I get back to building my wooden float I will use alder or ash . But your trailer looks awesome and won't burn like mine would ! Mike
Old 03-08-2015, 09:21 PM
TRUCKMAKER's Avatar
That's the first thing I thought of when I seen that! it realy looks good, the one pictures looks like a 1:1 sitting in a fab shop!
Old 03-08-2015, 09:29 PM
bigford's Avatar
you know the next pic cooper posts will be of his hand bleeding with 5 drill holes
in the plam
Old 03-08-2015, 09:50 PM
Cooper's Avatar
in the plam
At least I'm not using an air nailer!!!! Lol.
Mikem I originally had the idea of milling plank lines in a solid piece and staining the grooves for the appearance of planks. The wood I have is 1/8" thick. Now that you mentioned that I may do that, only thing is I have to tear down the mill some to get the piece to lay flat on table. Might be a good time to clean out underside of slides anyway.
Thanks guys!! Appreciate the kudos. So it's not looking too bad ?
Old 03-09-2015, 02:49 PM
Cooper's Avatar
This is what I was thinking about doing for decking. I'm probably going back to using the bass wood, the oak I have is really thin and I was basing my decking on 1/8". The oak is less than that and doesn't allow for a very good elevation lineup for the side boards. I don't have the tools to shave precision numbers off wood. And am trying to have side board extensions housed in middle of deck.
Old 03-09-2015, 03:32 PM
bigford's Avatar
your decking a trailer not the back yard deck for the wife!!
go with something like this http://www.ncnwest.com/rmi/equip.htm
Old 03-09-2015, 04:58 PM
Cooper's Avatar
Talking Re: Great Dane excavating co.
Lol!!!!!
Here ya go!! Lol!!
Got one side done between some quick real work jobs.
Old 03-09-2015, 06:47 PM
TRUCKMAKER's Avatar
Cooper take a look at the decks on the trailers on this site.
http://www.rogerstrailers.com
Old 03-09-2015, 07:02 PM
Cooper's Avatar
Ahh got you guys,,,,, and this is the reason I don't get paid to do this stuff . It looks like all these types of trailers leave the frame ibeams exposed and wood decking is flush with top of steel. I did not research enough I guess. . Hummm maybe a alteration is in need. Or it may be one of those trailer manufactuers that has gone out of business because of a poor design . Lol!! I guess I better not name it Great Dane trailer manufactuering ,lol!!! And I also realized I should have made some sort of alignment with where planks but up against each other. They don't match up to frame supports. Guess I got a bit ahead of myself to get-er-done!!!
Oh well it's my redneck construction company , gotta have something bassackwards!!
Old 03-09-2015, 07:21 PM
TRUCKMAKER's Avatar
Yeah it's always the easy stuff that"ll trip you up!
Currently Active Users Viewing This Thread: 208 (0 members and 208 guests)
