#141
Heres the link to their website Steve ..It wont directley link you to the tire but with a bit of searching you will be able to find them under Reifen
http://www.fechtner-modellbau.de/shop/ |
#142
thanks Lou , that rings a bell
#143
So you custom fabbed that brass tubing and holders, eh? Looks great!
![]() Are you changing the tires on the adt for better looks or are the mammoth tires giving you trouble? |
#144
Thanks joe ..I found that making bushings drilled to the size of the tubing worked fairly well ..I had some 3mm threaded fittings so i tapped the the ends and soldered the bushings to the tubing ...I noticed that those european fellas building their vario machines are doing tubing as well...Did your machine come with that stuff or are you going to have to build that yourself.?
The mamoth tires are working great..Im thinking the other tires may add a bit more scale and a little more tracttion. |
#145
Yesterday i managed to do a lttle testing and threw a load on the pacific...Dam forman showed up and parked his pickup next to the truck before the binders were put on..
#146
Lou I went in that web site and the only tire I could find was 120 mm tall I would like a set for my Komatsu wheel loader to get it taller so I can load my dump trailer and the 130 mm would help. Is there a part number for them? Ed
#147
Lou, That shovel looks good, a little paint and its time to go-ah-loggin. Nice work. Fred
#148
hey forman !!! I loved your pick-up
is it axial scx10 basis ? and could you write me brand of cab ? and final question is the inside hand made ? or not where can I get them ?
CAT: 963 B Scaleart // 345D LME Wedico // CS 563 E Handmade Mercedes Benz: SK 3544 AK 8x8 Premacon // NG 2636 AK 6x6 Wedico Handmade MAN TGS 26.500 6X6 Wedico - Premacon MACK Granite 8x6 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#149
Man you got a lot of work in that Lou! Its looks superb!
Brian |
#150
Lookin Good Lou
Looks like another project is almost finished.. greg |
#151
Awesome build Lou!! Great detail and it looks great! Time to talk with that foreman... Need some video of that unit before the snow fly's..
#152
The forman's truck looks perfectly sized sitting next to Your rig.
#153
Ben |
#154
Looking really good Lou. Can't wait to see it lifting and swinging some logs. His next job is to put those big arse tires on the ADT. Let me tell you guys they are something else when you hold one in your hand.
Rob |
#155
thinkin like rob said ..adt tires then get back to the grader build Quote:
Fred still adding a bit more detail and hope it warms up to paint..thanks |
#156
Lou thank you for the information I appreciate it. I think I will give them a call tomorrow and see if they have a tire that would fit the bill for me or maybe they can tell me were to get one. Ed
#157
Looks good Lou, I've not been around that configuration with the crowd cylinder on the bottom side like that, does it have as much power as the other way? Are you using the Jung pump on that rig?
Joe |
#158
The needed power on the crowd (or the stick, as I like to call it) for the log loader would be opposite to a digger, you're pushing the stick out with a heavy load on the arm, to load the trk/trl... would be my guess for the cyl being underneath.
#159
Right on Joe .
#160
Looks great!!!Lou you keep it up you'll be crankin out a model every month and a half ,........nice work though
| Currently Active Users Viewing This Thread: 132 (0 members and 132 guests) | |
| Thread Tools | |
| Display Modes | |
