| Construction News New kits & accessories offered in the world wide marketplace |
Found this German company that makes this compactor made of metal and thought it was pretty neat. They offer attachments for others models like rippers and buckets for the 4200xl and Magom 1.4 excavator.
http://www.funktionsmodellbau-brueckner.com/walzenzug/ ![]() https://m.youtube.com/watch?v=wlDNab...cZ0N2-4WHLhCww Last edited by Northern Farmer; 02-11-2018 at 01:35 PM. |
looks vey useful. this is an ideal compaction solution for foundation work. you could make stronger roads, bridges, buildings with this. excavator mounted compactors are good for trenches, but not wide areas. I want one of these
Yeah pretty neat model to have in the fleet. There's actually one for sale right now
https://www.facebook.com/groups/6452...14569458599771 |
Thanks for the post, this looks pretty affordable, and as you said a great addition to the fleet...
does it vibrate?
No it doesn't . I have a build post on mine.
http://rctruckandconstruction.com/sh...ighlight=bomag
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. If you got it, a Trucker brought it.... Last edited by MoRockN; 01-12-2016 at 01:17 PM. |
Then does it have a weight inside?
The first compactor in the pictures no, but they have another compactor with a vibrator inside the roller.
http://www.funktionsmodellbau-brueck...tionsfunktion/ http://www.funktionsmodellbau-brueck...tionsfunktion/ |
Try this guy for a Compactor roller, I have seen one of them work and looks fine to me.
http://www.rzmodeltrucks.com.au/ |
It says on their site that it weighs in at 3.8 KG. The wheel is hollow and you fill it with lead if you want.
Technische Daten: Länge: 420mm Breite: 185mm Höhe: 240mm Ø Walzrolle: 100mm Gewicht: Einsatzgewicht mit Akku: ca. 3,8 kg (ohne Zusatzgewichte) Die Walzrolle ist innen hohl und kann mit Zusatzgewichten (wie z.B. Bleikugeln oder einer Stahlrolle ) befüllt werden.
They look good, very good, simple design, easy to make.
But I dont know for you guys, but if I would build something like this, I would use steel, not alu. I guess more weight is a plus for something that needs to compact ground? I guess all manufactures make lighter models, as they are cheaper to ship, and dont need strong motors to get them move around.
Here's a good video demonstrating the Bomag rc roller
https://youtu.be/8_EkkN2pfnY |
With vibrator
https://youtu.be/uWnwD4QYuDk |
With front blade. Looks good
| Thread Tools | |
| Display Modes | |
