Old 12-21-2010, 01:54 AM
rc_farmer's Avatar
Master Builder
Default Re: 140H Grader
Lil bit more on the moldboard assembly. Got the braces done and the cylinder bracket made for the blade's pitch. Gotta clean all the solder up. I will sandblast all the metal before i prime it
Giving up is not an option!!!
Rob
Old 12-21-2010, 02:01 AM
rc_farmer's Avatar
Master Builder
I am going with the AT SD10G. I just got the nerve to sprang for a pump though, so the radio will be early next yr, after the holiday season.
Sand, sand, sand, then cover with fiberglass cloth and afix with CA. The CA fills 99.9 % of the cloth......sand, sand, filler, sand, sand.....rub ur fingers across it, then sand some more......then prime/paint
Originally Posted by SonoranWraith View Post
Looks awesome. You definitely would not know any of it is wood after that paint. Do you do a layer of filler or something to get it that smooth? Have you looked at the Airtronics SD10G? Not sure it is enough channels for you, but all the switches are 3-pos. The F-14 is expandable enough that it would work but with all the decoders it ends being a lot of radio gear.
Rob
Old 12-21-2010, 02:23 AM
rc_farmer's Avatar
Master Builder
Originally Posted by woodhog View Post
for you to have told me in jackson that you work with primitive tools you sure are turnin out a very nice project keep it up
Lol, all so true.....thanks alot, hows ur's coming along?
Rob
Old 12-21-2010, 09:22 AM
The circle and moldboard assembly is looking just great! Nice detail, and really like the novel approach to the circle gear - we often don't recognize a chain works from both sides and doesn't have to be the moving part. I agree with the others, how you make wood look like cast-iron is a wonder. Keep it up!
Old 12-21-2010, 02:27 PM
modelman modelman is offline
rcfarmer-your doing really great work! That model looks very complicated to me but looks like you have it well under control. Nice job!
Old 12-23-2010, 10:18 PM
This, your work, is insane, Rob! I cannot believe the painted parts for the blade lift are wood. This is going to be an incredible model, when done. I cannot wait to see what developes.
Old 12-23-2010, 10:56 PM
rc_farmer's Avatar
Master Builder
Thanks again guys. Here are a couple more painted pieces.
Rob
Old 12-24-2010, 02:14 AM
Mighty fine craftsmanship Rob and way to use your noodle for materials.
Old 12-24-2010, 07:48 AM
JAMMER JAMMER is offline
Thumbs up Re: 140H Grader
You are looking real good Rob. You are starting to make some real hear way. Ed
Old 12-28-2010, 02:53 AM
rc_farmer's Avatar
Master Builder
Here is a brief test the hydraulic steering........hooked it into my terragator pump to test how it should work.
Rob
Old 12-28-2010, 03:27 AM
It doesn't seem like it's turning very sharp or is it?
Old 12-28-2010, 09:34 AM
Graders don't turn very sharp but when he leans the wheels it will turn sharper.
Coming along nicely.
What motor rpm,pump pressure and gpm is your pump operating at?
Old 12-28-2010, 11:17 AM
rc_farmer's Avatar
Master Builder
When the wheels are on, you will be able to see the difference in the turning. I am going to use the Leimbach pump. Its only 10 bar. I may have to upgrade to a bigger pump later, but for now, i think this will work. Had to test it......couldn't wait for pump to get hear....., Hopefully it will be here by first of the yr.
Rob
Old 12-28-2010, 11:51 AM
td9clyde td9clyde is offline
Dozer Builder
i am really liking this build i always liked running the 140's alot better than the 120 this is going to be one cool build
Old 12-29-2010, 12:52 AM
RCLogger's Avatar
RCLogger RCLogger is offline
WOW very nice Rob ! ! ! You should give me a lesson on soldering, you have it mastered.
How many spools are you going to have in the grader ( functions )
greg
Old 12-29-2010, 01:57 AM
I guess I need to pay more attention when I see the municpal grader turn around, I thought they turned quite sharp without leaning the tires.
I wonder if the Mammoth tires will roll on edge, sidewalls might be too soft. Perhaps stuffing the tires with plastic BB's will stiifen up the sidewalls without adding too much weight.
What makes the difference in hyd flow is the size of hyd hose and fittings. What size do you currently have on your Gator Rob? 1.5mm ID?
My current excav & wheel loader are using 2.5mm with the 350ml/min pump and cycle speed is significantly quicker, I would say more than double, than the older models with same pump & 1.5mm hose/fittings.
rc_farmer's Avatar
Master Builder
Td9-I have never run any of this equipment before. I just like building different models.....I am building this one from pictures only. So far, I have probably taken about 200 pictures to build each pices.
Greg-6 spools when completely done. After building the Gator, the soldering is a breeze now , don't mind sharing any tips that might help ya
Patience is always the third hand....
Rob
Old 12-29-2010, 02:06 AM
rc_farmer's Avatar
Master Builder
I do have the 1.5mm ID. Getting all this hydraulic stuff right is the challenging part for me. I appreciate the info of the 2.5mm, which is what i think i need for the grader. I ordered the biggest tank from Leimbach. Good idea on the plastic bb, was going to add some to the rear as well.
Rob
Old 01-18-2011, 02:09 AM
rc_farmer's Avatar
Master Builder
Default New Pics
Here are some painted pieces. Enjoy!!
Rob
Old 01-18-2011, 02:38 AM
RAIDERS RAIDERS is offline
Super Moderator
RAIDERS is on a distinguished road
Paint came out very nice keep up the good work.
LARRY,the doggy dish dealer
