#1441
most impressive bead on the tank looks like you have been doing it for years!!!
farm looks cool too |
#1442
![]() Another thing to learn,, I don't know if I have the correct glue. If not I'll get some. After seeing ? The guy with the excavator, he made his tanks with acrylic and that's pretty cool. Thought I would give that a try.
#1443
RW, the new homestead looks very Stately! The welding looks great, I'm with Joe I need arm rests to steady myself and the eye sight is not conducive to good welds, I can run a bead but it usally isn't where it belongs. Can't see a thing when I strike an arc. Keep up the good work!
#1444
hey rw can you get your paws on M.E.K in pa?? that will bond your plexi parts together
N.Y. banned the sale of mek here due to kids huffing it |
#1445
Congrats on the house , now you can build a quarry , town , transship warehouse , railroad transfer etc etc . Mike
#1446
Congratulation Cooper ! To your new Home / farm / RC park and you passed the alum. weld class. As far as i can see you got the hang of it...
![]() Carry on please ! |
#1447
![]() Well I made the tank. I had some adhesive, several different kinds and did a test earlier today to see what one worked on acrylic and found one I have works. Takes up to 72 hours to cure. I have a small air pump to help ventilate inside. Hopefully speeds up set up and cure time.
#1448
Thanks bo , house is pretty nice, not really looking forward to moving but looking forward to moving in!! eBay time!!! The welding was going slow but once I got everything lined up and got one good bead it clicked and everything I had been reading made sense. Hopefully I don't regress on a part I have a bunch of tie into. But head swelling will be deflated when it does and I'll gain more appreciation for the guys doing it for a living!!! Already do!!
#1449
What a feeling it is when " it clicked and everything I had been reading made sense " The brain can go in recover mode and it just works.......nothing can stop you just going going.
#1450
That sure looks like a nice place. I always admire those big stone farm houses while traveling East.
Changing the subject; where did you get that fancy welding table? |
#1451
![]() Tank will be housed in side fuel tank Steve, thanks on the new homestead. Not much to do inside but a lot of small things needing repair on outside structures. The table was from certi-flat or tabandslot dot com. They later cut everything very precise and all you do is clamp and weld it together. I don't like to push products but these guys make a pretty darn good product and its cheep. Like $300 compared to strong hand tables that are $3000. Accepts 5/8" clamp tools. They have all kinds and sizes. I'll look up the website later. It's something like tabnslot or tabandslot dot com. The way it's cut and put together the top comes out being +\- a couple thousands. Not bad for a inexpensive table. Also has lockable casters.
#1452
That's a really good idea making it clear to see the fluid level. You have a beautiful home Cooper congratulations!
#1453
I got the idea of the clear tank from paolo, he is building an excavator and as long as the one I made doesn't leak I'll be happy!!
#1454
The only thing I would add is another outlet higher up in tank where you want the fluid level to be when it's full. Leave enough room for expansion when the oil gets warm and run the hose out the bottom of the Aluminum tank
Great looking ranch you got there but I don't see a dog house outside yet!!! Rob |
#1455
Coopers new dump box being delivered
#1456
Whoohooo!!! That's a big box!!!!
Finally got around to using the tig welder on steel. Wow a lot easier than aluminum!!! I guess I'm backwards because I learned how to tig weld aluminum first then steel. Definitely gonna be a very useful tool for building with sheet metal. These were the first parts I got to tig weld, mild steel onto stainless shafts. ![]() ![]() This is the start of the new garage/shop/ super-mancave!!!! ![]() Found a use for the one side tank, housing the prv and gauge. Not needing to access it too often. All the holes in cover will have screws but the whole box slips off with only a couple screws. ![]() ![]() And started running hydro lines. Working on hooking up electronics to get a first test run in tranny and hydro cylinders.
#1457
#1458
She was the first thing that caught my eye in the other group of photos. Have any of that pink silicone left?
Cold looking shop but I know it won't stay that way. I'm jealous of the space and happy for you now that you finally have it! |
#1459
Thanks reg! Humm, I may make some silicone,,, uh more tires,,,, lol!!! Garage is second thing on list of things to do. First is putting up a fence so my lazy but doesn't have to get the golf cart out to take the dogs for a walk
. Garage is next. That's more important (for me). Lots of stuff to do. Only thing I'm not going to do is the garage doors. Going to get the professionals to do that. Siding, drywall, insulation, concrete, wire electrical, Windows, gas line from house, ,,, lots to do!! Hopefully work this summer will be slow and I can get that done fast!!!Working on electrical hookups on dump truck now. And also have to relearn radio programming. Initially I thought I would have solder connections done tonight and test run, forgot about radio stuff, hopefully I have a spare receiver around. Hopefully have a test video in the next couple days.
#1460
Yes it is muuuch easier tigging steel, some instances you can melt two pieces together without filler rod.
Congrats on the shop space! spray foam? putting up any interior walls so you don't have heat entire building during the winter? 785 looking fabulous too, some very innovative ideas you've come up with to make use of interior space within the model, good job.
| Currently Active Users Viewing This Thread: 185 (0 members and 185 guests) | |
| Thread Tools | |
| Display Modes | |
