Old 03-21-2016, 04:38 AM
Claus's Avatar
Claus Claus is offline
Default Tamiya Reinforced Output Shaft?
Has anybody bought one of these? I'm guessing it's hardened? Stella models says "Attach this reinforced shaft in place of kit-supplied standard Gear Shaft B for more efficient power transmission and excellent durability".
http://www.stellamodels.com.hk/56538...ft-p-9547.html
Old 03-21-2016, 10:34 AM
Default Re: Tamiya Reinforced Output Shaft?
sounds like some slick advertising.... has anybody ever broken the output shaft? i haven't heard of that, but i don't run my trucks that hard anyways
Old 03-21-2016, 12:08 PM
If Joe has not broken one, don't bother buying one
Old 03-21-2016, 12:33 PM
bigford's Avatar
bigford bigford is offline
sounds like a message to janderson is needed
Old 03-21-2016, 02:16 PM
ricm ricm is offline
you'll chew up the nylon gears, the drive shaft cups and/ or the drive shaft grub screws will come loose before you do any damage to the shaft!
Most useful thing in that bag is the extra tube of grease
Old 03-21-2016, 02:48 PM
Claus's Avatar
I was just wondering what people's reaction would be. I can't really see a need for it either. I did upgrade to the brass gears and stainless synchronizers though.
Old 03-21-2016, 03:02 PM
bigford's Avatar
claus
have you opened your gearbox lately?
got this off facebook
Old 03-21-2016, 04:38 PM
Claus's Avatar
Just put it together last week.
Old 03-21-2016, 04:41 PM
Claus's Avatar
Old 03-21-2016, 05:39 PM
Claus's Avatar
Bigford, looks like lake of lube has been hard on your gears???
Old 03-21-2016, 07:22 PM
lake of lube?! stay outta the deep end...
sorry, i'm 5 years old...
but don't tell me y'all didn't go there too...
Old 03-21-2016, 07:36 PM
bigford's Avatar
LOL!! not my gears somebody posted that to facebook asking if it was normal wear
woops
Old 03-21-2016, 08:07 PM
Claus's Avatar
Well whoever's it is, it looks like they forgot the grease. How would any metal gears last without grease?
Old 03-22-2016, 01:05 AM
Cossett's Avatar
Cossett Cossett is offline
On Leave
The only thing Ive stuffed is the gear change rod in my second truck,
When I was setting up the sevo - gear change travel I bent the rod a little cause the power of the hitec I didnt set up the sevo travel properly and epa on it, not that its a big problem for me as I only wanted one gear in it and used two of the black plastic locking pins that go on the out side of the gear box,
But that was my fault not the tamiya product and then I just disconnected the gear sevo and drove the truck a few times with a load on it to find the best gear for it and locked it in.....
Sorry just realised your talking about the shaft's the the cogs go on, it just sounds like a gimick from tamiya to make you spend more money, if any thing the cogs are going to go long before the shaft will from tamiya, Ive heard of cogs going but not the shafts in the gearbox
Cheers Tracy
Love my Kenworths
Old 03-22-2016, 08:33 AM
Originally Posted by bigford View Post
claus
forget the lube, ehh ?????
Old 03-22-2016, 10:22 AM
HAH! that's funny Emil ...and true! The only failed part I have ever had in a stock tranny is the top middle aluminum gear for 2nd in the white GL that has a million scale miles in over a decade of run time.
That "HD output shaft" is about as necessary & useful as the brass helical gears... sucker's play.
The radical amount of wear on that above trans is probably less about lube & more about what that in runner brushless motor's top speed is set to?
Old 03-22-2016, 06:25 PM
That is exactly what I was thinking!!!!!!!!!
Old 11-19-2016, 05:36 PM
Claus's Avatar
I picked up a couple of those Reinforced Shaft Kits off of eBay, might be snake oil but am looking forward to installing them in my transmissions.
Old 11-19-2016, 06:12 PM
jack van's Avatar
jack van jack van is offline
so i have got 2 output shafts on the way 1 will replace pushrod i broke doing maintenance and i also got the automatic tranny for the next king i bought should be here next 3 days also got a mfu comming
