Old 03-29-2016, 08:13 PM
Cat966c Cat966c is offline
Default Hydraulics
I need a 2 1/2ish inch hydraulic and I'm not sure what I'm doing or how to find the one I want. I don't understand the lingo. The cylinder itself has to be around 2 1/2" long and 1/4" wide. It's for the arms of my 966
Old 03-29-2016, 08:18 PM
Default Re: Hydraulics
This one:
File Type: jpg image.jpg (157 Bytes, 259 views)
Old 03-29-2016, 08:22 PM
Argh, here we go
Old 03-29-2016, 08:34 PM
The one hinged to the light that controls the bucket
Old 03-29-2016, 08:45 PM
5mm bore x 50mm stroke
Old 03-29-2016, 10:10 PM
Ok I looked for that, but it's not the size I want????? IaI and some others make some but I can't figure out how to buy them or how much they are?
Old 03-30-2016, 12:34 AM
Is this one right? This is about the right length:
http://m.ebay.com/itm/AIR-CYLINDER-5....c100408.m2460
Old 03-30-2016, 09:05 PM
Well, what is it you want exactly ....2 1/2" stroke or overall length? 1/4" bore? or is it outward dimensions you refer to? I gave you the metric conversion above, if you were looking purchasing overseas of model specific made hydraulics.
The one in the link is only 1" stroke & a 5/16 bore will make it more likely 3/8 OD barrel & that collar on one end is probably 1/2" OD
Plus you're gonna have to fabricate your own pin bores ends to attach the cylinder on your loader arms.
Old 03-30-2016, 10:14 PM
Yeah, overall length/ outward dimensions.
Old 04-02-2016, 12:54 PM
Bump.
Ok; so I think I have the size figured out, now I need to know which cylinder is right for me, but I (again) need information. But at least now I know the bore and stroke sizes I need (;
I need a cylinder that has at least a 3/4" stroke and no more than a 2.15 inch cylinder. I think ultra precision makes one with that but I'm not sure. Also, magom doesn't list their cylinder sizes or specs on their site. Maybe somebody with their own magom cylinders could tell me? Any help would be appreciated.
Thanks
Old 04-02-2016, 03:10 PM
Metric conversion... 25.4mm = 1 inch
.75" = 19mm
2.15" = 54.61mm
what bore?
Send Magom an email to ask if they make custom cylinders for you.
Old 04-02-2016, 05:32 PM
Ok, thanks but I already emailed them and they just sent a list of their products and blueprints with no numbers or measurements and I don't understand the weird calculator thingy on their website.
Old 04-04-2016, 11:17 PM
I still don't understand the calculator on the magom site. If the A measurement means hinge pin to hinge pin, then what's the length of the cylinder by itself?
Old 04-05-2016, 04:06 PM
Looking at this page, you can buy cylinder kits of any bore to make any length of cylinder you want YOURSELF! Cut & solder... simple.
http://www.magomhrc.com/en/38-hydraulic-cylinders
Old 04-05-2016, 08:20 PM
Really? Will solder hold? I thought it had to be steel? So you can make a completely brass hydraulic? The forces/newtons/etc. aren't too much stress? Sorry for all the questions I know I sound super annoying and stuff
I'm so close!
[edit]
Another thing: I thought hydraulics were expensive but wow are they very reasonably priced! This is surprising. I thought that this stuff would be ridiculous and that's why I was avoiding buying them, but I can afford this I think (:
Old 04-05-2016, 09:36 PM
bigford's Avatar
bigford bigford is offline
cylinders can be cheap or real expensive. the big money come in the
pumps and valve bodies.
Old 04-06-2016, 02:03 AM
Yes, the brass ends & copper tube is soldered together... my JD850 is brass ends & brass tube, pressure @35bar, you won't be running that high on your loader.
Premacon has a nice hyd kit available for pump & valves, you'd need 3 valves... don't buy Magom's pump & valve set up, just looking at it gives me the shivers. Plumb your loader with 4/2.5mm fittings & hose, should give you good flow speed with 18mm bore cyls on the loader arm & bucket, 14mm bore for steering.
There's the cheap way to do things & maybe it works ok, depends on your expectations I guess... or spend a little more & do it right the 1st time & have it work awesome!
Old 04-08-2016, 11:22 AM
Ok, now I'm frustrated. The Robert pnuematics I'm looking at don't quite extend as far as I need and the homemade hydraulics technique I'm working on didn't work, now that I'm trying to do pure brass, I can't find either the pipe (o.d. 1/2") or the o-rings at he hardware store and they told me they dont make the 1/2" od brass pipe or smaller even though I've seen it in person and on here! Also while trying to grind the threads down on a brass nipple (the last ditch effort in trying to get my way of doing it to work) the grinder sucked my finger down in to it and ground half my finger nail off. Yay. It's worth noting that the way I was trying it would have technically worked (grinding the threads down so that the cap wouldn't screw in until it reached the remaining threads on the pipe).
So I think I'm just going to do the final thing I think will work: get a piece of galvanized 1/8" and weld my own custom cap up to fit on both ends and voilà!
Old 04-08-2016, 11:52 AM
I built the cylinders for my Tigercat skidder using brass ends and copper tubing soldered together. I also used steel pistons that are welded to the rod. It all works just fine despite it being a little crude. Oh, and I am running around 25 bar.
Old 04-08-2016, 06:08 PM
Yeah, that's what I'm trying but I can't find the tubing
