Old 07-11-2016, 09:26 PM
cummingsman29's Avatar
cummingsman29 cummingsman29 is offline
cummingsman29 is on a distinguished road
Default 4200 excavator issue
Ok so I finally got all the parts I needed to fix my new excavator from shipping, running well for about 15 minutes then the hydraulics started to run very slow I filled it to what it says or so I thought I also had a few leaks in it and think I got them all tighten up. Hoses showing like it has air in system could I have a internal leak someplace or just not enough fluid as it heats up it should expand, I'm running the rc4wd fluid. Thanks for any info
DONNY
EAST COAST MINI TRUCKERS
Old 07-11-2016, 11:36 PM
Default Re: 4200 excavator issue
I added another 75Ml on top of the 120 or 150 recommended. I had air in the lines when I ran with the manual recommended fluid level.
Old 07-11-2016, 11:40 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Mine did the same thing. Just added more fluid and kept running. Back to normal and still going.
LYNN
Old 07-12-2016, 08:33 AM
Thanks guys I will look into it when I get home!
DONNY
Old 07-28-2016, 12:03 AM
Efroeh Efroeh is offline
Did you get yours figured out? Mine is running slow also
