Old 08-15-2016, 09:09 AM
bigford's Avatar
bigford bigford is offline
Default Re: Cat D11
Robot market place 12volt 116 rpm ame motors
http://mobile.robotmarketplace.com/AME-218-2003.html
Old 08-15-2016, 01:29 PM
bigford's Avatar
Default Re: Cat D11
link to RW's d11 build
http://www.rctruckandconstruction.co...ead.php?t=7861
Old 08-15-2016, 10:04 PM
Cooper's Avatar
Cooper Cooper is offline
Default Re: Cat D11
Originally Posted by Rvjimd View Post
Cooper, at the show this weekend, did I hear you telling Steve or someone else that the dirt likes to get stuck between the grouser and the pad in front of it? On my little Oliver it does exactly that. I should have took a few close ups of your machine. Do you have a build thread here with a good pic of the track pads?
I'm thinking about machining a few prototype track pads and want to try to reduce the dirt problem if possible. Wonder if the grouser could be moved back a bit?
Mark, could you tell me where you ordered you motors and what the part number is?
Nice to see you both at the show!
Jim
Jim, originally I had pretty close clearance between the track pads, grousers didn't push too much into them. Titandigs was the one who told me I need more space between the pads. Like 1.5-2mm would be good. That's about the size of dirt particles / sand that like to wedge in between and causes them to arch up. As he said like a scared cat!! I ended up machining a bit more off them and that helped. Like mark said I think somewhere in that build thread I talk about it more.
The conversation I was talking to Steve at show was more towards having dirt pile up onto tracks from pushing or turning too sharp and it gets packed into the links from the road wheels and then the sprocket. Similar to someone running in a quarry, a good operator will take caution not to allow rocks to roll into tracks while pushing or turning. It's hard on the 1:1 machines and it binds up the tracks on our 1:14 machines. I was just referring to the links that are in contact with ground. Making a wider gap between shoes has helped with the arch in tracks. Don't know if you noticed but every once and a while I would put blade and ripper down , lift the dozer and run tracks. With that loose , dry dirt at the show that would usually loosen any packed dirt in the chain links and keep me able to get back to pushing. In wet dirt the tracks load up more from pushing too much and spinning the tracks. That's when they sometimes arch up. But once they rotate once it's usually resolved.
Wish I would have gotten more time to talk to ya, I always end up having a blast running the toys. .
Old 08-15-2016, 10:21 PM
bigford's Avatar
Default Re: Cat D11
at least you stopped to eat food this time
Old 08-15-2016, 11:44 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Re: Cat D11
Ah, that all makes sense, thanks!
Jim
Old 08-17-2016, 08:55 PM
bigford's Avatar
Default Re: Cat D11
what didn't happen at the pike show!!!
https://youtu.be/b5gmWAkeGTE
Old 08-18-2016, 08:32 PM
bigford's Avatar
Default Re: Cat D11
Non gangster reg!! (I hope)
https://youtu.be/TMXf0kLU9ZE
Old 08-18-2016, 08:37 PM
Northern Farmer's Avatar
Thumbs up Re: Cat D11
She's alive!
Old 08-21-2016, 09:45 PM
bigford's Avatar
Default Re: Cat D11
test #3 down at work
https://youtu.be/dhprkFEnW0g
Old 08-24-2016, 07:53 PM
bigford's Avatar
Default Re: Cat D11
Got the new blade arms and brackets
Old 08-24-2016, 09:05 PM
Claus's Avatar
Claus Claus is offline
Default Re: Cat D11
Looking good, needs a couple of chrome stacks.
Old 08-24-2016, 09:49 PM
bigford's Avatar
Default Re: Cat D11
Stop that!! Mule ears all the way
Old 08-24-2016, 11:28 PM
Default Re: Cat D11
Man that shovel is massive!
Old 08-24-2016, 11:51 PM
Default Re: Cat D11
Cooper, I've been following this build with great interest because I'm thinking of getting one for my next build instead of a "total build" like my 1/16th Russian T-800. Watching your tracks in the vids, have you tried the walking gear around the other way?. Because the the grouser bar is actually mean't to "lead" the grouser plate, not follow. You may find that makes a lot of difference in the walking gear. She's lookin good.
Old 08-25-2016, 12:08 AM
Claus's Avatar
Default Re: Cat D11
Mules ears can be chrome.
Old 08-25-2016, 08:55 AM
Default Re: Cat D11
Sorry, Bigford, not Cooper.
Old 08-25-2016, 09:31 AM
bigford's Avatar
Default Re: Cat D11
That's the way the tracks came from BB I can
Swap them around.. you think mario would have
Said something sooner.
Old 08-25-2016, 11:35 AM
Supermario's Avatar
Default Re: Cat D11
sorry Mark, I never noticed till now looking at the pics. absolutely true, tracks are on backwards.
Im going to blame my ipad and cracked, scratched screen because looking from my work laptop I see it clear as day now.
Old 08-25-2016, 12:50 PM
bigford's Avatar
Default Re: Cat D11
That's it your no longer the caterpillar kid
Old 08-25-2016, 01:20 PM
TRUCKMAKER's Avatar
Default Re: Cat D11
I guess we were mesmerized by the size and pretty yellow paint I didn't notice till now either.
