Old 10-09-2016, 12:59 PM
scottyk scottyk is offline
Default My Bruder conversions, Tracked skid loader and Bulldozer.
Im new to this forum and just sharing a couple projects I have done. I am new to this side of the RC world "construction stuff" but got addicted pretty fast after I completed the skid loader and playing with that in the sand box with the kiddo's. Now I have a bulldozer, and a Excavator I converted with Magom hydraulics and I love that thing! Soon I will have a dump truck. but until then here are some pics of the skid loader and bulldozer conversion I completed. Both are fully functional and work great I drive them all the time!
Lots of pictures in this post I will warn ya! Feel free to ask any questions or comment about anything. Thanks for looking
Old 10-09-2016, 01:00 PM
Default Re: My Bruder conversions, Tracked skid loader and Bulldozer.
And here are some pics of the bulldozer.
Old 10-09-2016, 01:01 PM
And a few after airbrushing
Old 10-09-2016, 01:05 PM
and of course some videos too...
https://www.youtube.com/watch?v=YVr-TkK7yQU
https://www.youtube.com/watch?v=vIvw6duLZMU
Old 10-09-2016, 01:34 PM
Nice conversions. I've got a loader myself, been in pieces for more than a year...
Old 10-11-2016, 07:58 AM
komatsu97 komatsu97 is offline
komatsu97 is on a distinguished road
Nicely done mate, very tidy.
Your dozer, what did you use for the extensions on the track plates?
Old 10-11-2016, 09:26 AM
I made those on my 3d printer, but they are very simple plastic strips just super glued into place. You could duplicate it simply by cutting or buying strips of plastic. Helps ALOT with traction but on carpet they grip almost too well and can bind it up. I've broken a transmission already with it and now I have a pair of transmissions that have a built in fail safe "torque limiter" built into them so hopefully that will save them. Works great on surfaces its designed for, light dirt and sand
Old 10-27-2016, 01:35 AM
Bluesdocbob Bluesdocbob is offline
Bluesdocbob is on a distinguished road
Hey Scotty the Drive wheels or the dozer and other bit that 3D printed did you make them and and how can I get some of the ... Cheers Bobv
Old 10-27-2016, 09:47 PM
Bob I designed and 3d printed them myself, the drive wheels did take a slight bit of modifications to work good since I made the teeth a little too long I had to sand them down a little but not a huge deal really. Send me a IM if you want a set. I actually have a really nice dual servo mount for the dozer that will work the blade up and down AND move the ripper and down, very compact deal.
I will say I am not 100% sold on the pololu dozer gear boxes yet, the axle is plastic and only protrudes about 1/4" from the side of the dozer after its mounted, but I have about 20 battery packs thru my dozer and all I have had to do is tighten the tracks so they are working so far, maybe it will be ok.
Old 10-27-2016, 09:54 PM
Old 11-24-2016, 08:58 PM
jeffgp jeffgp is offline
jeffgp is on a distinguished road
Is there any chance you will share stl file for the track sprocket
Old 11-25-2016, 12:39 PM
yeah I can do that, send me your email sometime
Old 12-01-2016, 07:44 PM
any more picture of the bucket mount for the skid loader .. it looks intersting ..
Old 12-03-2016, 12:06 AM
Hi Jeff I just checked back into this forum and got your message. I will look into my files here and send you some. the Servo mount for the bucket took a few iterations to get right but it does work very well. I will get you some more info, sorry about the delay I have been busy lately with new business ventures.
Old 01-22-2017, 03:18 AM
RcBruder RcBruder is offline
RcBruder is on a distinguished road
Smile Re: My Bruder conversions, Tracked skid loader and Bulldozer.
Hey. I was wondering if i could get the file for those drive wheels for the dozer. My dozer is in pieces because of those pieces lol!
Old 01-22-2017, 09:40 AM
kaptain Jack's Avatar
If you gonna go into production I would love to buy the set of those dozer drive wheels.
The once I have hand made suck.
Cheers
Jack
Old 01-23-2017, 12:38 AM
What are you guys using for transmissions? These wheels fit these transmissions and are the wrong size hole for a tamiya transmission, I might be able to make some adjustments tho let me know what your looking for.
Old 01-23-2017, 04:09 AM
I am mounting on servos. I will cut to size with my dremel. I notice the teeth are longer as well? If so, that's awesome as that is the problem that i am running into. Thanks!
-Rc
Old 01-23-2017, 09:45 AM
Mine is still on Tamiya, but I will switch it for something stronger, since I keep on frying the motors
Thanks
Old 01-23-2017, 10:46 AM
Well the motors in these gear boxes are the same size as the tamiya gear box so I wouldnt consider that a upgrade. The output shaft has 2 flats on them so that is the shape I made in the wheel. I was thinking about changing to a tamiya gear box actually since these gearboxes have a short output shaft similar to a servo and when running a track they get alot of side load and deflect. Where running the tamiya box would give you a longer steel shaft and seems like it would hold up better.
I will say I have broken teeth off on both styles of gear box so the strength is about the same, fairly weak! I try to stick to sandboxes and tilled up dirt in the garden so they dont get real good traction.
So with that being said I will work on another version of the dozer drive wheels and let you guys know when I get it figured out, RCBruder do you have a measurement for the wheels you want, Id assume you want to bolt a round servo horn straight to the wheel so give me a measurement from the mounting flange to the inside edge of the teeth.
