Old 02-12-2017, 05:11 PM
Efroeh Efroeh is offline
Default Re: Eagle Mach JD-98/RC4WD DXR2
OK thanks Benny. I found rc4wd to be painfully slow with dealing with them. Sucks when you buy somthing new and it's broke right from the get go.
Old 02-14-2017, 06:08 PM
thebigo thebigo is offline
Originally Posted by TheBennyB View Post
Parts are on their way with a tracking number. Tang is very good at working with you to get any problems solved. Just have your camera ready as they like pics to go along with busted or missing items to show them exactly whats up. RC4WD is the same way.
Was running mine the other day, and all of sudden my blade wouldn't lift but it would lower ???? So after working back through the hydraulic cylinder's to the valves, I found that the servo to valve actuator thingy was not tight. Had to disconnect all the hoses to the valve block, pull the block out, and found that two of the set screws were not tight or locktighted. Ended up lock tightning all the set crews and re- assembling the machine, about a full day's job...
Oh well, I like working on them so no big deal, but pay attention to this problem.
David
Old 02-14-2017, 07:09 PM
Thanks for the heads up.
Old 02-21-2017, 09:40 PM
Got my parts in. Will try and take some vid this week. Here's a question for the dozer owners. If you have them, how are you running your lighting kit wires? Know I can take off the tank cover, sponson's, hood manifold cover, etc. and drill some holes. Was just wondering if anyone had any tips?
Old 02-23-2017, 10:31 PM
Haven't got that far yet, I ordered mine from RC4WD, and didn't get the sound or lights. Bet you could easily mount your switching unit and external battery, if that's your option for light, under the tray right under the hood because there is ton's of room!!!
The room is plenty in this outfit, but I am now building a LR634 and let me tell ya its tight, especially when I have about every option you can think of.
The light's thing is a learning experience for me, so I probably will be getting with you and others for help.
David
Old 02-24-2017, 12:40 AM
Yea, lots of room on the DXR2, no need for external power for lights(runs off 5V from RX), just need a Y splitter if you want to go eagle light system. All channels used on RX. I went off Ch 9 which also had the BEC. Not sure if that will effect voltage or not. Got the heads up it should be good to go from Tang at Eagle so I've got an argument if things go black.
Old 03-02-2017, 09:54 PM
Any videos of the dozer working yet?
Old 03-03-2017, 09:37 AM
Not yet, we actually got some winter style weather so ground froze up. I messesd with it a bit a week or so ago but didn't take any vid, performed pretty well. When ground warms up will take some vid.
Old 03-24-2017, 06:54 PM
Sorry no good vid yet, hopefully tomorrow unless it rains. Trying out Rick Grimes from "Walking Dead" to operate the D10.
Old 03-29-2017, 10:18 PM
Finally shot a vid today. Material was wet after a good rain the night before. Nothing real exciting and a bit long winded, so grab a beer and let me know if there's anything specific you'd like to see if this sucker will do it (within reason...)
You'll hear the one planetary still chattering like it's not meshing correctly, just can't figure what's up with it yet.
Gonna operate through another batt or 2 then take them apart to see if any unusual or uneven wear is visible.
https://www.youtube.com/watch?v=bkXK6eBJG0A
Old 03-29-2017, 10:41 PM
Hey Benny how do you find the blade right mess and staying level? The blade seemed to be higher on the right or is it adjuastable?
Old 03-29-2017, 10:49 PM
You have tilt control, just touchy. You can also adjust on the stay bar, though that adjustment affects tilt and angle of attack (pitch) on the blade. For the most part if you see anything working in the wrong it's probably user issue on the TX and not the machine. If your playing on a relatively level area it'll hold, other wise you have to adjust your blade accordingly. My play area is full or roots, rocks, sticks, snakes, frogs, etc. so it's hard to get a clear control to compare. Never really see anything completely level.
Old 03-29-2017, 10:59 PM
I watched your video and it seemed you were doing a good job running that rig. How do you find the build quality and would you recommend it to someone else?
Old 03-29-2017, 11:37 PM
For sure. The only issue I've come across mechanically are the planetary's and they still work just not sure for how long. This also seems to be only with my machine, haven't found anyone with the same issue. There are some annoying design features, mainly the access to the fluid tank in which you have to remove the tracks, cab, and fight with the sprockets to get to some tiny hex screws under the fenders to remove the cover over the fluid tank. Still once you've done a couple times it's not too bad. Overall a decently detailed machine that'll move some real dirt and looks frick'n awesome doing it!
Old 03-30-2017, 02:38 AM
Northern Farmer's Avatar
Thumbs up Re: Eagle Mach JD-98/RC4WD DXR2
Great video Benny
Old 04-01-2017, 11:01 AM
Front end disassembled for Paint. The hood and blade cylinders will be going black. Also some fuel for the operators...it was a good day!
Old 04-01-2017, 11:57 AM
Oh man I don't know what looks better that dozer with some dirt on it or that meat. That's it I'm firing up the egg for supper tonight.
Old 04-02-2017, 01:02 AM
Did you end up firing up the egg?
Old 04-02-2017, 01:15 AM
Yes I did, did up some pork chops chicken kabobs and some broccoli for myself and the wife.
Old 04-02-2017, 01:30 AM
Real nice! Food drunk enough to pull the trigger on the dozer?
