Old 04-17-2017, 08:20 PM
Default Bruder 574 RC conversion weekend project!
Hi!
I know there has been a lot of Bruder 574 conversions, but not one like this one..
The goal was to try to convert the Bruder 574 to RC with the very least amount of work during a weekend. (Easter had a long weekend and thus it would be possible)
Note that there is no steering servo in this conversion!
There are some 3D-printed parts in the front and in the back:
The front and rear axles are 30mm aluminum tubing with 2mm walls.
I re-used the wheels:
All the wheels are drive by a 12v 24rpm gear motor:
The hubs I got from Ebay didn't have a thread, so I tapped a M4 thread in them:
I 3D-printed a stencil to help guide where the holes should be:
Then I assembled the rear pivot:
Cut away the fake axle to make room for wires going from the front to the back:
Assembled the front section:
Like in the rear there is a small screw holding hitting a small hole in the axle that fixes it in the printed part:
The motors are held in place by two M4 5mm long set screws, one on each side (for balancing the position in the tube):
I remove one screw from the firgelli actuators and re-insert that into the holder. That way the actuator is fixed inside the holder:
Old 04-17-2017, 08:29 PM
Default Re: Bruder 574 RC conversion weekend project!
I re-purposed the original Bruder axles in both ends of the boom cylinders. The new lengths were 100mm and 85mm. I cut away that part that previously held the wheels.
I 3D-printed another stencil to help guide where the holes in the bottom should be. It's important to do this before cutting away the original axle mounts, otherwise there will be no reference points:
3D-printed a stencil for the top holes as well:
The top cylinder is mounted with two M4 screws:
For the boom cylinder mounts, i just added something to avoid them sliding inwards:
Old 04-17-2017, 08:35 PM
Video:
https://youtu.be/MBxpjOn_Arw
Old 04-18-2017, 05:01 PM
In case anyone wants to try the same approach, here are the 3D files:
The full model in Fusion 360 format:
- BruderLoader+v13.f3d
The individual 3D-printed parts:
- BoomCylinderMount.stl
- FrontBottomHolesTemplate.stl
- FrontSideSpacer.stl
- FrontStructure.stl
- FrontTopHolesTemplate.stl
- RearAxle.stl
- RearAxleMountFront.stl
- RearAxleMountRear.stl
- WheelBoltsTemplate.stl
Old 04-18-2017, 07:09 PM
That is awesome! Great conversion, and thanks for offering up files so others can follow your lead.
Old 04-18-2017, 07:40 PM
Thanks, Frizzen!
Here are some specs on the parts too:
- A normal 4ch RC transmitter and receiver (for once no embedded PC :-) )
- 1 x 3S battery ~2000mAh
- 2 x Sabertooth 2x5 R/C
- 4 x JGA25-370 12V 24RPM
- 1 x L12-S Actuator with Limit Switches - 30mm - 100:1 - 12 volts
- 2 x L12-S Actuator with Limit Switches - 50mm - 100:1 - 12 volts
The steering is controlled by wiring the motors such that both the front and the rear part move as tanks, but in opposite directions. I only use one controller for both the drive and steering. The other controller controls the boom and bucket.
The wiring for the drive motors:
- Channel 1: Front left motor + rear right motor
- Channel 2: Front right motor + rear left motor
The first motor controller works in mixed mode. The other in normal mode.
Stein :-)
Old 04-18-2017, 11:05 PM
Efroeh Efroeh is offline
Awesome conversion very well thought out design. Great job
Old 04-19-2017, 12:09 AM
Fantastic work! Really awesome stuff, good thinking on the templates as well.
Old 04-19-2017, 04:05 AM
Thanks, Efroeh and TheBennyB!
Stein :-)
Old 04-22-2017, 02:33 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Very cool, thanks for the detail, I like the different ideas you used!
Jim
Old 06-15-2017, 06:10 PM
Here are two videos of the first dirt digs:
At least it digs normal dirt with small rocks and all, even if it's not a full bucket on each load. :-)
Stein :-)
Old 06-16-2017, 09:16 AM
kaptain Jack's Avatar
Man, thx for sharing the files, very kind of you. And job well done.
Old 06-16-2017, 01:21 PM
Rvjimd's Avatar
Turned out really nice! Thanks for the files! I haven't yet, but will download them just in case I decide to do one of these!
Jim
Old 08-09-2017, 06:56 PM
I see that I've left out some information:
- The aluminum axle tubes are cut to 135mm length.
- The wheel hubs (4mm axle) were bough here: http://www.ebay.com/itm/322385127356
Best regards,
Stein :-)
Old 08-10-2017, 12:21 AM
THANKS for the link to E-bay parts! I've been trying to find those for a project I've had laying around. I ordered one each, 3, 4, 5, & 6MM. Once I see which one(s) fit the best, I can them buy more of them.
Old 08-27-2017, 04:29 AM
A great big THANK-YOU, sir for sharing the STL files. With todays addition of a 3D printer, I can now make one of these. I'm excited to get started, just have to wait for the delivery of the Bruder loader to get here................That, & have some spare time. LOL! I know when winter gets here, I'll have more than enough spare time to complete ALL my projects, & then some.
Old 08-27-2017, 08:15 AM
Thanks, Skeeter! :-)
Congratulations on your newly acquired printer! :-)
I've also put the files up on Shapeways if there anyone not owning a 3D-printer but still wants to get the parts made:
- https://www.shapeways.com/search?q=s...D+loader&type=
I think Shapeways is very expensive, though...
There is a third alternative and that is https://www.3dhubs.com/
There you can get the parts printed on someone's 3D printer close to you.
Best regards,
Stein :-)
Old 08-27-2017, 08:30 AM
Rvjimd's Avatar
Skeeter,
I'm jealous, sounds like a LOT of fun getting to learn and play with a new 3D printer and converting a loader! You should start a build thread including setting up and using the new printer!
Stein,
Thanks again for sharing the files and knowledge!
Jim
Old 08-27-2017, 09:12 AM
Thanks, Jim! :-)
Stein :-)
Old 08-27-2017, 03:00 PM
I bought a smaller radio for my sons to get a better grip:
- https://hobbyking.com/en_us/turnigy-...er-mode-2.html
It did not have self-centering for all the axis on the joysticks, so I opened it up to see if there was just something to screw loose or something like that to get it to self center.
But there was a part missing to get the self-centering functionality. I copied the design in Fusion 360 and 3D-printed a new part.
- STL file: http://d1t2tbzmskak12.cloudfront.net...tickCenter.stl
Also, the spring was missing. I took that from an old donor radio.
Putting it back into the radio:
The end result:
(now with self-centering on all axis)
Stein :-)
