#2201
Having seen your previous work, I know that when it's all did & done, it'll be well crafted, & look amazing.
#2202
I should have guessed.
BIG DUMP TRUCK + BIG LOADER=LARGE MATERIAL OUTPUT 🍻 |
#2203
me thinks RW is getting serious about diggin out the barn & getting an INDOOR play area!
#2204
Thanks skeeter, and yes!! Have the perfect project for many years to come. Once I get the time I'm going to make an indoor screening plant. Large scale!! Well still scale to our equipment but want to move a lot of material. I have a lot of dirt that has been dumped for fill from rock raking /seeding yards. Perfect to haul into barn and then use the scale equipment to process. And best part I'll gain that wasted soil back. Might take a couple weeks to process a couple yards and then just a couple scoops with 1:1 equipment
. But it is an endless supply with a purpose. !!
#2205
That'll be great to see you fab that up Cooper... you build a Vario sized excavator & a couple cubes could be done in an afternoon.
#2206
That payloader will move more material then any
Excavator could |
#2207
That axle is looking good RW, looking forward to more updates!
#2208
Update,, still have some minor things to change but gettin the gist of it.
![]() ![]() The drive shafts are long, they will be cut to size later ![]() ![]() And I left enough material in relation to rims and hub to be removed if tires shrink more than anticipated from the mold process. That's kind of difficult to calculate precisely. (At least for my redneck engineering)
#2209
Oh and bearings will be farther onshaft for a retainer to keep them. I just don't want to pres them in yet. And I'm going to eliminate the chamfer between the two axle parts , I don't want that gap. Like I said still working on some fits and tweaks
#2210
Beautiful!
Kerst |
#2211
That software for your mill opened so many doors for you.
#2212
About how much machining time do you have in 1 axle? Your machining is outstanding!!
LYNN |
#2213
. Lots to learn for a simple mind like me . And lots to improve speed up on. But I'm not trying to speed things up as in a production environment but just hate to see slow movements when tools are not engaged in a cut. . And after the initial program was proven to do what intended. The bearing pockets were a few trial/error and sneaking up on proper clearences to get them a snug hand press fit. Wasn't using a boar tool just path and the tollarances on machine are pretty good. I'd say I get a good 80% score mark all way around bearing pockets. Good enough for me .
#2214
Great work CB. Shows you are paying attention to the little things. Ed
#2215
Been a while so some data dump,,,
The back axle trunnions, ![]() ![]() ![]() ![]() ![]() Steve (Ihbuilder) gave me the good idea of pressing on a piece of stainless for the bushing. Now the bushing material will slid against steel instead of aluminum. Thanks Steve . The back axle oscillates something like ?? 10 degrees.
#2216
Front axle/frame mount
![]() ![]() ![]() ![]() I still have to drill holes in axle. Wasn’t sure about how everything was going together at time. Still have a bit of the redneck engineering, build parts first then figure out how to fit them together !!!
#2217
And now working on the frame that pivots along with mounts for turning rams
![]() ![]() Building them to accept a tab and slot construction that will align and be welded together . On the 1:1 no hardware is visually in frame as they are cast and welded pieces. So I didn’t want any screws visually and welding is needed. ![]() Still have to cut holes for the steering rams and bolt holes. These pieces required 6 different set-ups. Time consuming,,, as another said welcome to the machineing world
#2218
Wow
There are several leagues in this hobby, and you are playing with the very best. Looking forward to more pictures.
#2219
![]() ![]() ![]() ![]() The side extension supports[/QUOTE] Me not being a machinist, how do you separate the milled supports from the base strip? Do they require another step to get to finished thickness?
Big iron is awesome! |
#2220
This build is amazing.....and huge! Looking forward to seeing it in person one day. Think it will make Cabin Fever 2018?
| Currently Active Users Viewing This Thread: 54 (0 members and 54 guests) | |
| Thread Tools | |
| Display Modes | |
