#1661
Just waiting for some videos now
You got yourself a haul-beast
#1662
You betcha Emil, banged out about 20 loads yesterday... now I got a couple hrs of trimming to do with the dozer, did the east side of shop just before dark last night, it was crazy hot here yesterday, 35C, do the west this morning before the heat returns.
![]() ![]() https://www.youtube.com/watch?v=xuHLKHgAgB4
#1663
Smoothed out west side Saturday morning
![]() ![]() ![]() ![]() Used the B50 & pup to fill in the holes along the walls ![]() ![]() Tonight I weighed out my cross dump train, the 1st try with plywood platform was doubled up & screwed together 3/8... not strong enough ![]() Screwed a 3rd layer of 3/8... weight of platform is 38lbs ![]() Loaded weight 219lbs (-38lbs) ![]() ![]() Empty weight 137lbs (-38lbs) ![]()
#1664
Wow 82lbs of dirt!!! And the tractor with both trailers weigh 99lbs empty.
Are both trailers powered at the wheels? Last edited by liftmys10; 07-08-2018 at 11:57 PM. |
#1665
Yes, brushed motor at each wheel, 12wd.
#1666
Watching your video I was wondering with all wheels being powered and as long as the combination is, do you have any kind of problem with the wheels on the last trailer when making a sharp turn as the radius is so much shorter than the other axles?
#1667
Whenever I turn at about 45 degree or less, it's at half speed, the motors aren't working at full power they tend to behave like an open differential to some extent & usually no added tx stick movement necessary. Both trl chs on Slave are mixed with tractor being Master.
#1668
Nearly finishing the 1st bench cut; I knew it was too high @17" with about a 2:1 slope, the hoe was 3" from the edge but it was always sinking a little as I reached out to fill the trls. Dozer time, new bench about 6" high will make loading much easier & SAFER! It'll be three more bench cuts to get down to the hardpan.
![]() ![]() ![]() Got a nice blast rain this morning @8am, 2/10's in about 10 minutes, a welcome cool down after four days of 35C... I forgot to put down my eave extension last night ... got some dump trk hauling to do to fix the road ![]() ![]()
#1669
Wow, that cross dump is a beast!
Glad to see you've got some time to play again
#1670
Thanx frizzen, it has been an enjoyable couple of weeks in the shop, cross dumps have been working awesome, I like my redesign of the hopper doors on the 2nd trl, I think I will zip disc the doors off the 1st trl & make the same... after summer hauling.
#1671
Hey joe estimated time till job completion
#1672
Can't believe how smooth and flat you get the benches! More dozer videos please!
Jim |
#1673
nice pics joe and the sorting sure makes for some nice material. hopefully before too long I get my screening project up and running. you don't get too much rock up there do ya, that crusher you have is that primarily used to break hard clumps?
#1674
Ah moving out the stock pile Mark? Try to get it all out before the white stuff comes again... I finished clearing that lil bench today, it's been so incredibly hot here last 2 wks with a few rainy days too, spend early mornings doing odd jobs on the farm, hide in the shop during the heat of the day & some nights an hr before dark hauling out or blading... get it done in moderation, don't wanna be too fast at it
![]() Thanx Jim dirt is quite dry & grainy, easy to blade smooth compared to the rocky/lumpy dirt you tangle with in your videos... make yourself a screener & crusher like me & then you'll have nice dirt to work with too. That lil dirt pile took about an hr to smooth out, you'd probably be the only one patient enough to watch it all. ![]() For sure Cooper, the screening & crushing activities add to the enjoyment value in keeping the equipment moving, Not a lot of rock?... I guess that depends on what you consider a lot of rock... in my soil I have everything from garden pea size/sand to watermelons.... not far from home I have some fields with rocks the size of Datsuns, when they get to sticking out of the ground too much, I then get the local TLB to either fish them out & skid 'em to the nearest rockpile or if they're too big to handle the op will dig a deeper hole to roll the rock into to get it a few feet below the surface, I likely won't see it again in my lifetime. Everything from hardball & smaller rock goes thru the crusher, anything else larger gets hand picked & hauled away in my Ranger. ![]() What's left for fines ![]() Some rainy days in the last week, crushed some dirt lumps & rock ![]() Got a big pile to put the thru crusher before winter ![]()
#1675
Ya, I would call that a big pile!
![]() Jim |
#1676
I'm glad to see there's a possibility for more videos coming on Youtube
#1677
Looks almost finished. Time to start hauling it all back inside again. Once it's filled in again, then you can dig er out again!
#1678
Skeeter, the back of shop is my holding area from winter digging, got get it empty so I can dig some more... finally nearing the end of the dirt piled up from the tunnel dig a few yrs ago (about 28 cubes)... finish the tunnel this winter, cutting in the steps & get back to digging the basement floor.
A lot of hot days in the last couple weeks, last week in the 40's... the dirt lump pile just about gone ![]() ![]() East & west sides of shop are pretty to close to finished; now dumping on the north side, build up a sharp taper to the edge of trees. ![]() https://www.youtube.com/watch?v=TXWs4jy6mzo
#1679
Joe,
You probably already answered these questions, but is your crusher just a typical jaw crusher and are you running dry dirt thru it? Any trouble with clay sticking to the jaws? How do you have it set? Pretty close? Looks close from the fines you make. 40! That is hot even me, a Fahrenheit guy, thinks that is hot! The only few I have memorized is 0-32, and 28-82 so 40 is HOT! Jim |
#1680
Nice work Joe-enjoying the videos as always.
| Currently Active Users Viewing This Thread: 64 (0 members and 64 guests) | |
| Thread Tools | |
| Display Modes | |
