Old 10-02-2016, 11:17 PM
550166681 550166681 is offline
550166681 is on a distinguished road
Default Re: How to make hydraulic valve?
very good !
Old 12-14-2016, 02:00 PM
thetractorfan thetractorfan is offline
thetractorfan is on a distinguished road
Originally Posted by Jw. View Post
Please excuse my poor cad abilities as I'm still trying to learn. This is the manifold I quickly drew up to help explain.
Thank you so much. I looked all over the Internet for cheap hydraulics and I was supprised to see how expensive hydraulic valves are. Many places charged into the hundreds in Euro's just for a 2 way valve and the models I want to build need many more valves and components which weren't getting cheaper.
Old 12-15-2018, 08:16 PM
Cat966c Cat966c is offline
Could I use plastic for the valve rotor?
This thing:
File Type: jpg EEFCA28A-B90F-4522-8919-64A189444D6A.jpg (157 Bytes, 105 views)
Old 12-15-2018, 08:17 PM
Grrrr. The thing in the bottom pic in the post above
Old 12-16-2018, 03:13 PM
I would ill advise it. I'm no hydraulic expert, but I do know I've experienced an RC machine that had plastic incorporated into the valve design. It wasn't long before it leaked & was useless. I wound up buying a valve spool from Magom in Spain to remedy the manufacturers crappy designed valve.
Old 12-20-2018, 11:43 PM
Thanks!
Ah, darn ��
What about the valve itself (thing the rotor sets in) could it be plastic?
Old 12-22-2018, 01:30 AM
I wish I were more help. I know limited amounts about hydraulics. Alls I know is I threw away the plastic crap that was causing the issue & upgraded it to a full metal valve spool.
Old 12-25-2018, 12:46 PM
Nah man, you’re a big help-thanks! ��
Old 12-26-2018, 12:45 AM
Maybe some kind of ultra high molecular weight plastic? You'd probably spend more and longer trying to find a plastic that's stable enough at pressure. Looks like the RC systems keep it under 500psi, so it's not too crazy, but trying to figure out forces doesn't sound fun.
Can your tools run Brass?
Maybe go Aluminum for the valve body, but i might be concerned about galling if you run aluminum for both the block and spool though.
Might be able to add some teflon sheeting at the faying surfaces without very much redesign, then surface finish in the block wouldn't be quite as critical.
Might want to check around your local machine shops, if you've got a small one that does one-off stuff they could be a big help. But you also might find a production valve system price is close to theirs anyway...
*not a machinist at all. I just have decent grasp on theory, and operate some high pressure stuff*
