Old 03-12-2019, 11:19 AM
Default Re: CAT 14M3 Motor Grader
Originally Posted by tracksntreadslou View Post
Nice work Ari ..3D cad can be very challenging at the best of times .your first grader build inspired me to build one as well..Your work blows me away .mine has been coming along fairly well and always trying to do some upgrades and details ..heres a vid of it doing some snow work ..
https://www.youtube.com/watch?v=JZTlPB4x5fs
Thanks.
I've already watched your snow work videos, great work. I love the working windshield wiper
Old 03-17-2019, 11:00 AM
I got the blade done
Old 03-23-2019, 09:50 PM
That blade looks good!
Old 03-24-2019, 10:03 AM
I got some parts made for the blade side shift mechanism
Old 04-12-2019, 12:47 PM
This is the blade tilt cylinder and it's bracket.
Old 04-13-2019, 06:39 PM
Kiffer Kiffer is offline
Kiffer is on a distinguished road
Beautiful work
Old 04-15-2019, 04:19 AM
Great work as always!
Old 04-23-2019, 06:52 AM
I've been making the hose connectors and soldering them in place
Old 04-30-2019, 01:47 AM
Beautiful work!
Old 06-05-2019, 06:36 AM
Hi guys, it's been a while since last update.
I've been drawing the cab and the engine enclosure, and those parts I was thinking to 3D print. You who have used 3D printer for parts like those, how would you print them ? Do you print it wall by wall flat the build plate, or how would you do it ?
I got some machining done also. This is the rear sub frame for the ripper
I was trying to upload these pictures from Photobucket, but no matter what I did they showed up on the original size I give up, switching to Postimages.
Old 06-09-2019, 07:34 AM
Welded together and in place
Old 06-13-2019, 12:40 AM
I got the cab base plate and the under plate done
Old 06-13-2019, 06:32 AM
This is the engine compartment base plate.
Old 06-14-2019, 07:21 AM
I made the engine compartment front wall.
Old 06-16-2019, 03:52 PM
How I'd print the cab would depend on the size of it. IF it was small enough I could get in on my printer in one shot, I'd try it that way first.
Old 06-27-2019, 10:13 AM
Thanks man !
That would be the easiest way, I'm just a bit bit worried about how the window openings will turn out.
Old 06-27-2019, 10:28 AM
I made the first side wall for the engine enclosure. It's quite awkward shape as it get wider at half way and the upper front corners are bevelled, due better rear visibility.
Old 06-28-2019, 07:58 AM
Both sides done
Old 06-28-2019, 02:00 PM
ederson's Avatar
ederson ederson is offline
ederson is on a distinguished road
ola boa tarde muito impressionante todo seu trabalho eu gostaria de ver um vídeo destas soldas é possível você fazer um vídeo de como você faz estas soldas?
Old 06-30-2019, 06:30 AM
Here is a video of the welding process. It's not this project, but you get the idea.
https://www.youtube.com/watch?v=YoXMCrlaGT4
Currently Active Users Viewing This Thread: 17 (0 members and 17 guests)
Copyright ©2000 - 2026, Jelsoft Enterprises Ltd.
