| Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
#861
#863
Looking good, Bo!
#864
That's a really sharp Merc outfit. Was it an old tamiya body, or Freddy custom?
Are the trailer tires supposed to have that much offset? Looks good either way.
#865
Thanks, Frizzen. Yes, Freddy cut that body and made it to a day cab, model short. The Trailer has the longer axles, 140mm. I think duals have 120mm if I remember right. After the Merc, I will rebuild the Trailer to extendable, the trombone type and more axles, of course.
#866
Some other stuff arrived. Let's do this.
[IMG] IMG_6226 by Bo Wallen, on Flickr[/IMG][IMG] IMG_6233 by Bo Wallen, on Flickr[/IMG][IMG] IMG_6232 by Bo Wallen, on Flickr[/IMG]Out with the weak suspension. [IMG] IMG_6234 by Bo Wallen, on Flickr[/IMG]And push in the new. [IMG] IMG_6236 by Bo Wallen, on Flickr[/IMG][IMG] IMG_6239 by Bo Wallen, on Flickr[/IMG][IMG] IMG_6237 by Bo Wallen, on Flickr[/IMG]I am done for today, G Nite. |
#868
The steering mod. Is all done, The extreme short wheelbase makes this truck to turn sharp, very sharp.
![]() [IMG] IMG_6248 by Bo Wallen, on Flickr[/IMG]I also need to fit the Heavy Haul Push/pull couplings front and rear, and Plates has to relocate. [IMG] IMG_6255 by Bo Wallen, on Flickr[/IMG]Air tanks and "battery" box also in the works to be installed. [IMG] IMG_6252 by Bo Wallen, on Flickr[/IMG]More to follow. Last edited by Bo Wallen; 06-26-2020 at 12:34 PM. |
#870
Whats coming next Bo?
Thanks Nick To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#872
ooo very nice! whole new fleet eh?
If you are looking for cheap tamiya based driven steer axle conversion kits then watch my store
#873
Thanks, Nick. Yes, a slight extension to the fleet, Your front axles will be needed for two of the Benz.
The Lesus is just garbage
#874
Here is a sneak preview for you ![]() ![]() ![]()
Thanks Nick To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by NRS91; 07-01-2020 at 11:04 AM. Reason: Resize Pics |
#875
Thank You, Nick. I have a good feeling about your project. I will Have your product Incorporated in my fleet. The original Tamiya axles are right, and if they get tuned tight when built, they will last a long time. I have axles with far more than three hundred hours on them, still running smooth. So let's have the two current Mercedes on the bench run your front axles.
I am looking forward to working with you. Nick. |
#876
#877
The Mesh is extremely important on casted gears; There is no shortcut at that.
However, Tamiya does not make metal parts in the house. Therefore the gearbox has two different pressure angles on the gears, Old standard and new. Witch makes the gear to go down faster than it would with the same pressure angles. Now Japan is a monoculture, so the boss does not know that, and a new gearbox or axles will not be on the horizon for some time. But the work so I stick with them. |
#878
#879
Just came across this site again. Over Milion's views.
https://www.youtube.com/watch?v=NNVn8fLy5Ro
#880
Today I started designing the solution for the weakest part in the gearbox, Hope it will work as good as I hope.
[IMG] IMG_6268 by Bo Wallen, on Flickr[/IMG] Design and Machining, my self. Hardening outsourced. [IMG] Screen Shot 2020-08-03 at 10.55.25 AM by Bo Wallen, on Flickr[/IMG]
| Currently Active Users Viewing This Thread: 91 (0 members and 91 guests) | |
| Thread Tools | |
| Display Modes | |
