#141
The tip is replaceable, I milled out the back and used the split pins to hold it in place.
#142
Thanks for the kind words guys !
I guess you could say its a little brother, but Dan it is from another family compared to your machine. Mine is stand a few hundred feet away scale compared to yours.LOL Nathan I use photo's from the internet and I scale up brochers. As far as the track tension, I do use a spring in the track frames to keep the tension, also if a rock or any type of debree goes into the idelers the spring compensates. If you look at the 1-1 the pivot point is just ahead of the sprocket on the track frame. They have a system to keep the proper track tension as well... |
#143
Wow, you work quick. It looks great. What will you do with your other dozer?
#144
Great progress Greg! Love that you made the tooth on the ripper removable, then when it wears down from ripping rock you can change it out
#145
A little more work done on the ripper. Still have some more work to get it finished up.
#146
![]() I think you mentioned using air cylinders from McMaster for this and other projects...they hold up pretty good? I think I like the looks of those better than Clippards. Keep thinking I need to do something to turn down the square ends on the Clippards. Joe |
#147
Why don't you order direct from TTM Modellbau? Order in bulk, bank wire, you'll have your stuff inside of two weeks.
#148
love the chain drive. looks very useful!
#149
awsome work i am likin the 8 looks great keep the pics rollin
#150
fantastic build so far... starting to like these scratch built dozers a lot more... "potters off to ebay to look for a milling machine!"
Elliot. |
#151
The Ripper is almost a done deal. Ready to start the next section.
![]() IMG]http://i124.photobucket.com/albums/p17/logger_02/finishedripper002.jpg[/IMG] |
#152
#153
#154
greg |
#155
Looks good greg ...I may have to come have a look at that bad boy in person this weekend.
#156
Greg, The Cat is looking like a piece of "Aluminum Art", How many hours a week are you able to work on this project? Looks like you are ripping rite along. Fred
#157
Greg! That Unit is looking Serious!! Ripper makes that Unit!! And looks like it has lot's of depth for ripping.
#158
Greg you are doing a very nice job on that dozer looks great keep it up. I like your single tooth ripper better than the multi tooth. Ed
#159
I had a chance to mount some pads on the chain today
#160
Greg Looking better every day. Did you spin that side up. If you put some lead in her, she'll have some serious push for the blade and pull for the ripper
Rob |
| Currently Active Users Viewing This Thread: 135 (0 members and 135 guests) | |
| Thread Tools | |
| Display Modes | |
