Old 11-30-2021, 12:20 PM
Default Re: CAT 14M3 Motor Grader
Originally Posted by Zabco View Post
Beautiful work as always. Are you using a filler wire on your welds or just doing a series of spot welds?
Those are all spot welds.
Old 11-30-2021, 07:13 PM
I thought so but wanted to make sure. I want one of those pulse tig welders so bad I can't hardly stand it. Keep up the amazing work.
Old 12-01-2021, 05:07 PM
Them lil boogers are EXPENSIVE! Around $8,000.oo U.S.D. for the one that is capable of welding any & ALL types of metals! There are cheaper options that will ONLY work on steel.
Old 12-05-2021, 12:53 PM
The teeth are ready
Old 12-06-2021, 05:55 AM
I got everything welded in place
Old 12-06-2021, 10:50 AM
ederson's Avatar
ederson ederson is offline
ederson is on a distinguished road
perfeito acompanho sempre suas construções e admiro muito o seu talento parabéns!!!
Old 12-06-2021, 08:02 PM
JDToumanian's Avatar
JDToumanian JDToumanian is offline
JDToumanian is on a distinguished road
It looks more like $3,000 total to me, unless you're seeing some needed accessory I've missed, but I checked the website... it's about 2,500€ for the unit, magnifying shield, regulator, and shipping to the US. You should skip the regulator and buy one in the US, as I believe the bottle threads would be different.
Jon
Old 12-12-2021, 06:51 AM
I test fitted the ripper to the grader, still needs the cylinder
Old 12-18-2021, 02:37 PM
I started to make the lift cylinder
Old 12-19-2021, 10:07 AM
The cylinder is done
Old 12-26-2021, 07:03 PM
And that just in time for Christmas
Old 12-27-2021, 09:29 AM
I blasted the parts with glass before painting.
Old 12-27-2021, 10:26 AM
Pretty parts right there!
Old 12-27-2021, 08:10 PM
bigpipespete bigpipespete is offline
bigpipespete is on a distinguished road
Do you know what the weight of that machine will be once completed ?
Old 12-28-2021, 05:33 AM
It's slightly over 12kg (26,5 lbs), without battery and the ripper. I think they will add about 1kg.
Old 12-28-2021, 09:48 AM
Painting in progress
Old 01-03-2022, 11:41 PM
Jon
They've came down in price. It's been a bit since I last looked at them!
Old 01-07-2022, 09:32 AM
I got everything painted, the cylinder is still missing the piston seals.
Old 01-07-2022, 01:10 PM
Tgrzes Tgrzes is offline
Tgrzes is on a distinguished road
That came out really nice!
Old 01-07-2022, 07:32 PM
ederson's Avatar
Vai ter vídeo no YouTube??
